Input to U2 will be limited to +/-300mV. If the gain of U2 is 8, the output of U2 will be +/-2.4V. The gain of U3 is adjusted in such a way that the Vout will fall within +/-5V.
Since the Vout swings within +/-5V only, I plan to supply the U3 with +/-12V instead of +/-15V as shown in figure below. What're the possible effects on the op-amp performance with lower power supply?
Cheers.
