Author Topic: Info req. Dave's old function generator design.  (Read 1771 times)
Online wilfred
« on: June 11, 2012, 01:22:44 pm »
« Last Edit: August 22, 2018, 01:42:34 am by wilfred »
Offline LEECH666
Re: Info req. Dave's old function generator design.
« Reply #1 on: June 11, 2012, 02:54:07 pm »
Some German page mentions HA-5002 from Intersil as a possible alternative. I can't evaluate how true this statement is. Slew rate and Bandwidth seem similar.
http://www.intersil.com/content/dam/Intersil/documents/fn29/fn2921.pdf
Florian
Offline aaronwan
« Reply #2 on: June 11, 2012, 02:58:53 pm »
I made reference of Mr. Krzysztof Marcinek's design to build my MAX038 function generator. AD811 is used in the output stage. It's hot so I put a heat sink on it. The generator works fine for me so far.
You can find the updated schematic from the URL
http://www.kafka.elektroda.eu/podstrony/MAX038.php
Please note the diodes across the two LM337 for protection on the negative side for 5V and 15V supply are in wrong direction!
Offline LEECH666
« Reply #3 on: June 11, 2012, 03:03:32 pm »
When I searched for 2000V/┬Ás I came across this:
http://www.analog.com/static/imported-files/data_sheets/AD844.pdf
The suggested AD811 seems to be even better speced.
Meh whatever,
Florian
