inkjet gave rise to customer abuse.
Oh please, that's absurd. The razor-and-blades model was well established by then, having been introduced decades ago by, you guessed it, Gillette.
i had what i consider the best inkjet,
canon BJ330
black&white (well just black) A4 with tractor-feed.
AND the ink cartridge also contained the waste pad - looked like an 8-track tape.
no waste box in the printer, no chip in the cartridge, no automatic cleaning to waste the ink.
Waste recepticle in the ink tank is a cool idea. For the low print volumes in consumer models, though, it just doesn't make sense to add the machine complexity of that, given that almost nobody actually fills the spittoon.
That printer most certainly does consume ink in automatic cleaning -- that it doesn't was such an absurd claim that I looked up the
service manual, and it says that the cleaning function (which wipes the head and then "fills the nozzles with fresh ink") "is automatically performed when the power is switched on, before printing starts, or when printing starts after 24 hours or more". Moreover, it has the "maintenance jet function that ejects ink from all the nozzles of the bubble jet head to ... prevent the nozzles clogging", which "automatically operates when turn [sic] on the printer, before printing starts, every 12 to 30 seconds during printing, or every 1 hour for 24 hours after power on."
So yeah, it's using ink for cleaning, just like every inkjet.
and then came HP & Epson to destroy the fun.
eeproms, heads on cartridges etc.
Many, many early inkjets used integrated heads in the cartridges, including the HP ThinkJet (the first commercial desktop inkjet, 1984), Canon BJ-10 series, BJ-200 series, etc. Canon and HP now both use integrated heads in their cheapest printers, and permanent or semi-permanent heads in higher-end models.
Epson inkjets have never used integrated heads, and like most printers had no chips in the ink tanks until the 2000s.
Why did ink cartridges get more and more expensive over the years? Because the printers got cheaper and cheaper. In the end, you're paying a similar amount of money over the life of the printer. The same thing has happened to laser. And as always, very expensive printers with cheap consumables do exist for users with high print volumes.
