Author Topic: Resistor color chart that you favor most ...  (Read 9691 times)
Offline Kiriakos-GRTopic starter
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« on: May 22, 2010, 06:13:58 pm »
Well my old  " Resistors color chart"   , that I usually have glued on my lab wall , died from age ..
If you have find one well designed , and like to share it ...
Just attach it on this thread ..  :)
Offline safarir
Re: Resistor color chart that you favor most ...
« Reply #1 on: May 22, 2010, 07:12:28 pm »
All I need is my iphone and iResistor (Or something similar)
  • Country: gr
  • User is banned.
« Reply #2 on: May 22, 2010, 07:16:37 pm »
Do you glued it, at your wall too ?   ;D ;D
Do not let the software to effect your life that much... friendly advice ..  ;)
Offline safarir
« Reply #3 on: May 22, 2010, 07:50:24 pm »
If you really want a poster, use velcro:
My advice, enjoy all the benefits of new tecnologies
  • Country: gr
  • User is banned.
« Reply #4 on: May 22, 2010, 09:20:03 pm »
its still on my wall :)
If you do not take a picture of it , I will send Greek Ninjas , to take the wall with anything on it ...  :P  :D :D
Offline RayJones
    • Personal Website
« Reply #5 on: May 22, 2010, 10:13:12 pm »
My chart lives in my head, and is not reliant on one solitary wall.
4 band resistors are always a challenge, but when in doubt, use a meter!
Offline orbiter
  • -0 Resistance is Futile
« Reply #6 on: May 23, 2010, 12:02:10 am »
I don't have a chart, but I'm using a brilliant little tool at the moment on my pc. It's called Electronics Assistant 4.1 and is available here....
http://www.electronics2000.co.uk/
Offline DJPhil
« Reply #7 on: May 23, 2010, 01:15:28 am »
I use a small program as well, as I don't have wall space for a chart really. It's all shelves full of junk!
Miscel
If you've never heard of it, give it a try. Very small, lots of neat features. I run it on my eleven year old laptop for bench reference. You do have to tinker with it a bit to see how things work, but it's fairly intuitive.
The color code part has a handy 'best fit' output for different E series, as well as covering just about everything else with a color code. You can left/right click on the colors to add/remove them from the resistor model to get a quick read on something, or type in a value to see it.
It's got about six billion other uses, but I just threw in these two screen caps to show the color codes bit.
Offline allanw
    • Electronoblog
« Reply #8 on: May 23, 2010, 01:50:42 am »
Wow, I didn't know about these software tools. They seem handy. I also use this:
http://saturnpcb.com/pcb_toolkit.htm
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #9 on: May 23, 2010, 03:02:59 am »
ok! ok! u wanna picture? i give u one... just dont send your ninjas here.
quite hard to take it as its behind my "rack" where i put stuffs. and i dont think its for professional use.
Offline thedigitalprincess
  • DERP
« Reply #10 on: May 23, 2010, 03:46:11 am »
Resistor Color for iPhone xD
Got done doing 126kmph on the Fed Hwy at Collector but not at Base or Emitter.
  • Country: gr
  • User is banned.
« Reply #11 on: May 23, 2010, 04:24:56 am »
Water level detector ... was the practical subject at my exams , so to graduate as electrician.
I had all the materials as  tank of 40L,  three floating sensors, and an secondary set of three sensors as backup .
I had to install all of them , and be operational, so the water pump next to me, to start and stop when needed.   :)
At the EEVblog , we should had our own  Resistor color chart , even with the face of Dave in it ..  :D
« Last Edit: May 23, 2010, 04:26:37 am by Kiriakos-GR »
Offline xani
« Reply #12 on: May 23, 2010, 08:34:09 am »
One of these days im gonna print A2 page with all useful things and hang it on my wall ;]
For now "eTools" on android, its 2 way (from-to colors) resistor calc + some other calculations (atm LED resistor calc and capacitive/inductive reactance calc)
Online jahonen
« Reply #13 on: May 23, 2010, 09:39:28 am »
I am also among those who had to learn the colors at school (required in exams) when I studied as a service technician. I think I learnt them even before that school, as it is faster and thus more convenient. So I prefer the table inside my head. In fact if I look for particular resistance value I tend to think that as series of colors, instead of "decoding" each resistor.
I have since studied BSEE degree and moved to design side instead of trying to fix other people's stuff, but I still find useful knowing the colors. Although nowadays SMD 0603 resistors are the standard ones I use, and often have same information in plain text (albeit in very small font).
Regards,
Janne
Offline TheWelly888
« Reply #14 on: May 23, 2010, 09:41:11 am »
I use a chart that I torn out of an RS catalogue.
Here is a useful way to keep the colour code in your head.
0      1       2     3         4        5       6     7       8     9
Black Brown Red Orange Yellow Green Blue Violet Grey White
Bye Bye Rosie Off You Go Bristol Via Great Western
My old school Physics teacher was a dirty minded sod, he taught us this to remember the light colour spectrum Roll Over Your Great Big Innocent Virgin!
« Last Edit: May 23, 2010, 09:46:22 am by TheWelly888 »
You can do anything with the right attitude and a hammer.
  • Country: gr
  • User is banned.
« Reply #15 on: May 23, 2010, 10:14:48 am »
Well this is what I had in mind ,  its the larger that I found so far.
http://www.solidmotion.co.uk/TablesCodes/Resistor-ColourCode.jpg
Tip ,  if you plan to print something like that, set the printer to high quality.
And the most important ... use as Gloss paper ..Photographic quality paper ..
I am still looking , for the best chart ...  if there is one ..
  • Country: gr
  • User is banned.
« Reply #16 on: May 23, 2010, 11:39:29 am »
The best hardware chart ....  ;D ;D ;D ;D
Offline RayJones
    • Personal Website
« Reply #17 on: May 24, 2010, 08:09:04 am »
0      1       2     3         4        5       6     7       8     9
Bit more depraved, "Bad Boys Rape Our Young Girls But Violet Gives Willingly"  :-\
Offline Excavatoree
« Reply #18 on: May 24, 2010, 12:32:08 pm »
I'm among those who have the codes in my head - I can't imagine having to whip out an iphone, chart, card, or go to a computer to decode a resistor.
Most people memorize a ten word phrase, but that is awkward - to get to grey, you have to think B___ B___ R____ O___ Y___ G____(No, not that one!)  B___V____G  Ah, that's it.  Grey is 8.
Back when I took Vocational electronics in High School, I learned a silly system that associated each color with a number.  After a while, I, just like a previous poster, just think "five" and "Green" at the same time.
  • Country: gr
  • User is banned.
« Reply #19 on: May 24, 2010, 02:09:17 pm »
in the end, the DMM will talk :)
If it say {LEAD} or {OL} just electrocute it ..  the Satan got in it ...   ;D ;D ;D ;D
