Unfortunately, despite the correct information he received on terminations, he hasn't got a damn clue what he's on about.
Please elaborate? (In a PM if necessary; not sure what the thread hijacking rules are like around here.)
Eh, it's thoroughly hijacked already, and it's informative.
I assume the hottest part of the wire is the outside perimeter, since that carries the current.
DC or low frequency AC, no skin effect..
I don't know about the relative resistance of steel in the crimp compared to solder
Crimps are plated copper, not steel. Unless you got the wrong ones in a big way..
but it is conceivable to me that the relatively sharp edged taper of the solder might make a sharper corner than the looser fit of the crimp
It's the physical change in the material, not how tight or loose the fit is.
