Author Topic: Input signal appearing on the +Vpin of an opamp  (Read 2071 times)
Offline YaminTopic starter
  • Country: mv
« on: September 13, 2020, 09:18:23 pm »
A weird question I know, but some years back at college I remember while we were working on some op amp circuitry we detected our sine wave input appear on the +V pin of the op amp. Can't remember what we made of it back then.
This can't be normal right? I think I am having a similar issue on a project I am working on right now. Unfortunately I haven't got a scope to test it out at the moment.
Anyone had a similar experience? Is it a common failure mode for op amps?
Thanks
Offline Zero999
  • 0999
Re: Input signal appearing on the +Vpin of an opamp
« Reply #1 on: September 13, 2020, 09:28:04 pm »
What configuration are you talking about?
Are you talking about the positive power supply rail? It sounds like the isn't enough supply decoupling, or the impedance of the power supply is too high.
  • Country: mv
« Reply #2 on: September 13, 2020, 09:41:38 pm »
Yep on the positive supply. I am working on a guitar practice amp at the moment and this is on the preamp stage. It's in an inverting amplifier configuration.
Could I please ask you to explain what you meant by "the impedance of the power supply is too high".
Thanks a million
Offline niconiconi
  • Country: cn
« Reply #3 on: September 14, 2020, 09:00:30 am »
What Zero999 said is that, when the opamp tries to amplify a signal, say, a sine wave, its current consumption increases. If the power supply impedance is too high (high resistance connection, no bypass/decoupling, or if the circuit is somehow broken and draws more current than expected), the supply voltage at +V drops according to Ohm's Law. And after the sine wave peaks, voltage starts to decrease, and the current consumption of the opamp decreases again, voltage drop at +V decreases. The final result is that you see the output signal of the opamp has "leaked" into the +V rail. Another related problem is common-impedance coupling - if many chips are connected to the same power supply without any bypass/decoupling capacitance, the behavior of one chip can cause the power rail voltage to drop, and this drop affects other chips as well.
Not sure if it's related to your problem, just to explain "the impedance of the power supply is too high".
« Last Edit: September 14, 2020, 09:02:16 am by niconiconi »
Offline Zero999
  • 0999
« Reply #4 on: September 14, 2020, 11:06:53 am »
See the simulation of an inverting amplifier, with a power supply with a resistance of 100R. The red trace shows the output signal superimposed on the supply voltage.
  • Country: mv
« Reply #5 on: September 14, 2020, 11:14:29 am »
Thanks @niconiconi and @Zero999 for the detailed explanation. Sorry to sound like a complete noob but here goes - This would be considered as a fault or a bad design right? It's not supposed to happen?
In a case like this would it indicate that the op amp is faulty or needs to be changed or the decoupling or the bypass capacitors needs to be changed?
Thanks for the help really do appreciate it.
Offline Zero999
  • 0999
« Reply #6 on: September 15, 2020, 09:59:03 am »
No, the op-amp is fine. It will be due to a bad connection/power supply, or poor decoupling.
The following users thanked this post: Yamin
Offline TimFox
« Reply #7 on: September 16, 2020, 03:23:18 pm »
If one op-amp impresses that much input signal on a power-supply line, then you will see cross-talk (unwanted coupling) to any other amplifiers sharing that power-supply line.
  • Country: mv
« Reply #8 on: September 17, 2020, 09:50:58 am »
Umm..I did come across some material which points out that this could be done on purpose by the designer (as in, its designed so that the VS pin follows the output  :-//). That can't be right??
So to troubleshoot the unit I am working should I have a look at the decoupling caps on the power rail? Should I add a cap on the power rails to see if I could rectify the problem I am having? If so what would be a good value to check?
Thanks so much
Offline Zero999
  • 0999
« Reply #9 on: September 17, 2020, 12:25:28 pm »
It depends on who sensitive the circuit is. Normally the power supply rejection of the op-amp will handle variations in power supply voltage.
Yes, it's posible to design an op-amp circuit like that, so the output and power supply rail share the same connection.
Thanks so much
Check the connections to the power supply first. What sort of power supply are you using?
  • Country: mv
« Reply #10 on: September 17, 2020, 02:40:06 pm »
Thanks so much
Well I am working on a practice guitar amp, there is tons of noise on the final output. Not even possible to hear the input signal. I'm troubleshooting around the pre amp section. There is a DSP section inbetween the final output and the preamp. The power supply is a 19V power brick (I have tried different power supplies). There are some LDO regulators and the 12V is derived from there.
Could you please explain to me why that would be the case (sorry to sound like a noob).
Thanks again.
« Last Edit: September 17, 2020, 02:51:09 pm by Yamin »
Offline TimFox
« Reply #11 on: September 17, 2020, 02:54:12 pm »
Yes, a good op-amp has a decent PSRR, but now that single-supply op-amps are prevalent, the required bias divider (as in the OP's circuit) can easily couple more voltage to the non-inverting input than the equivalent offset from PSRR.
Offline Zero999
  • 0999
« Reply #12 on: September 18, 2020, 10:01:10 pm »
The original poster hasn't posted a schematic. Are you referring to the one I posted? If so then yes, it doesn't have great power supply rejection, but that's easy to resolve by increasing C1 and/or adding another RC filter before the non-inverting input.
Thanks so much
What sort of noise is it? A hum, buzzing noise or hiss?
Thanks again.
The main reason would be to simplify wiring, as only two conductors are needed, or a single wire if you can use earth return, but it makes the op-amp circuit more complex. Here's an example. The output of the op-amp is connected to its positive supply, which is connected to a power supply, via a resistor. The power supply and resistor could be at one end of a piece of cable, with the amplifier and traducer at the other. The amplifier has two different gains: DC and AC or signal frequency. At DC the op-amp has a gain of 1+R2/R1, which amplifies the voltage on D1 by 11, causing the output to sit at just over 6V. At AC, R3 is in parallel with R2, making 100k, so the amplifier has a gain of 2. For higher AC gains than 11, put R3 and C3 across R1.
« Last Edit: September 18, 2020, 10:09:05 pm by Zero999 »
Offline TimFox
« Reply #13 on: September 19, 2020, 01:49:34 pm »
Yes, I was referring to your posted schematic, which is typical for single-supply operation of op-amps.  (I was looking for a typical circuit and saw yours, but hastily referred to it as the OP's.)   PSRR of single-supply circuits, including bias chains, is an important design consideration.  I was involved in a re-design of a system with over a thousand dual-rail op-amps at the end of long power distribution wiring, and we had to add point-of-load regulators to avoid cross-talk from one end of the chain to the other due to power supply impedance.  (This was due to the PSRR of the op-amps themselves, and the class-B output stages pulling relatively large currents from the supply at high output voltage, thus affecting the voltage at other amplifiers far away, resulting in non-local crosstalk.)
« Last Edit: September 19, 2020, 05:48:53 pm by TimFox »
