They are not 'copper lines', but linear openings in the solder mask. You can faintly make out the actual copper track and pad areas in your photos, and they are much larger than the pads.
The purpose of these copper exposures, as mentioned, is to reduce the amount of solder that stays on the pad during wave soldering. Thus saving the manufacturer some money - significant over thousands of boards.
