Author Topic: Interesting take on the combustion engine - LiquidPiston  (Read 5078 times)
Offline daqqTopic starter
  • Country: sk
    • My site
« on: February 15, 2021, 07:48:12 pm »
They claim that they are 30% more efficient and 10x more power dense than the competition. While this does raise a few alarms in my head, they seem pretty serious and they seem to work:
https://www.liquidpiston.com/
I don't have enough knowledge on the matter to judge whether this sort of thing is fishy.
Offline RoGeorge
Re: Interesting take on the combustion engine - LiquidPiston
« Reply #1 on: February 15, 2021, 08:10:58 pm »
Looks like some sort of Wankel engine to me (not a mechanic).
https://en.wikipedia.org/wiki/Wankel_engine
However, the level of bullshit and fluffy words in those videos raised me a flag.  I couldn't bare it, skipped through the two videos without sound, sorry.  Same about the musical background.  Cringe advertising like one would need to do for a scam, not saying it's a scam just that it looks like one, maybe they just hired a really bad advertising team.
I would be very cautious, and go there to see and test the engine myself before investing.
Offline Benta
« Reply #2 on: February 15, 2021, 09:05:23 pm »
"Inverse" Wankel. Has exactly the same same thermodynamic issues. Certainly not my choice when buying stock. And ICEs are slowly dying anyway.
I'd call it a "conversation piece".
Offline Stray Electron
« Reply #3 on: February 15, 2021, 09:44:31 pm »
   It's still a Wankel engine and will suffer from all of the problems of a Wankel engine.  The high speed at the tips of the rotor will cause rapid seal wear and wear of the interior of the engine block (the equivalent of the cylinder bore in a normal piston engine). That wear will cause exhaust leaks and dilation of the intake fuel-air mixture which will get worse with time.  Both of those will cause emissions issues and will prevent it from being approved in most countries. Among other things, Wankels are basically like a 2 stroke engine in that they don't have a separate crank case and combustion chamber so they need to have oil added to the fuel mixture, either manually or via an injection system. The oil is consumed in the combustion and that will cause even more hydrocarbon emissions.
   This MIGHT be a good engine but it will never be approved for production in any modern country due to emissions problems. A good modern piston IC engine can easily run for 250,000 miles but no Wankel has ever come close to that due to the oiling and the wear problems.
The following users thanked this post: hans
Offline hans
« Reply #4 on: February 15, 2021, 10:25:12 pm »
The 'how it works' page states: "While it is a rotary engine, LiquidPiston’s X Engine is NOT a Wankel engine. It has a fundamentally different thermodynamic cycle, architecture and operation."
But it doesn't really state  what is revolutionary. And when I hear rotary engine, I immediately think about sport car engines like  the Mazda RX-8. Great for a fun car  with smooth power delivery,  but it  needs  tons of revs to perform (some RX-8 engines deliver peak torque at 5.5k rpm and power at 8.5k rpm) and are not economical at all (and thereby efficient).
I'm sure it can live up to the compactness factor to some degree; because it basically fits 3 cilinders around a rotating cilinder+crankshaft. One issue I think however is the geometry. If you decide  to build a larger engine (e.g. 1.5L for a road car), you need to  fit 3 large cilinders. The way those inlet/outlets are drawn makes it harder to build a 2-rotor design. The  only way is to then go out in width/height, which is unpractical. It also needs a good bearing and seal between gasses and the crankshaft.
I believe the RX-8 wankel engine is also loved because you can mod it to a 3/4-rotor rebuilt design. AFAIK you can  even reuse many parts  of the  original 2-rotor design, as it's quite a  modular block.
The following users thanked this post: jeffjmr
Offline nctnico
« Reply #5 on: February 16, 2021, 04:13:14 pm »
I'm not quite sure this concept qualifies as a wankel engine because it is very different and there are 3 burns during one rotation. It looks more like a rotary engine which uses the Atkinson cycle. But you are right about the potential problems with getting the rotor sealed. If this where such a good invention then car makers would have jumped on it long ago.
Offline richard.cs
  • Electronics engineer from Southampton, UK.
    • Random stuff I've built (mostly non-electronic and fairly dated).
« Reply #6 on: February 16, 2021, 04:54:05 pm »
Is the "liquid" just some marketing name? I was expecting something like this https://en.wikipedia.org/wiki/Humphrey_pump
Offline tom66
« Reply #7 on: February 16, 2021, 05:46:52 pm »
I don't know why anyone would try to create a startup company to market a new ICE,  the technology is dying.
Sure, it will still be around for another 15-20 years,  but the applications for this product look to be at low power levels (go karts, power tools, etc.) where already electric motors and batteries are competitive -- it looks like an increasingly small portion of the market and not necessarily a better solution (it's more efficient but who measures the efficiency of their weed-whacker?  Is the fuel even a significant cost?)
Offline nctnico
« Reply #8 on: February 16, 2021, 06:23:43 pm »
Not at all. Look for the KPMG 'automotive outlook 2020' report. It says that in 2050 (about 30 years from now!) 75% to 85% of the cars sold will still have an internal combustion engine. With ever tighter emission regulations and need for higher efficiency it still pays of to invest in ICE technology.
Offline David Hess
  • DavidH
« Reply #9 on: February 16, 2021, 09:16:45 pm »
It is only a Wankel engine in the sense that the rotor and stator are swapped, so in this design, the seals are stationary allowing them to be continuously lubricated.
Offline tom66
« Reply #10 on: February 16, 2021, 09:25:04 pm »
That would surprise me.  Perhaps if they're counting developing nations, but most European nations have committed to eliminating the ICE by 2030-2040.  Whether they hit their targets is another matter,  but automakers seem to be aiming this way.
Offline Sal Ammoniac
« Reply #11 on: February 16, 2021, 10:52:34 pm »
It's always amazed me how well modern IC engines work considering the large number of moving parts that all need to operate in a coordinated fashion. I guess that's a result of over a century of development. Contrast that to electric motors, which have a single moving part and are far far simpler than IC engines.
"That's not even wrong" -- Wolfgang Pauli
Offline retrolefty
« Reply #12 on: February 17, 2021, 01:20:05 am »
 There was never a question of the superiority of electric motors over ICE engines. The problem was/is the power density of the energy sources used.
Offline tom66
« Reply #13 on: February 17, 2021, 08:45:52 am »
I think it's worth putting in perspective though.
An average car might do say 250,000 miles before the ICE needs a serious rebuild.  If that car did an average speed of 40 mph - a mix of highway and city driving, say, that's a runtime of about 6,000 hours.
It's not uncommon for machines to exceed that so in some senses you could ask why do ICE vehicles require such regular servicing and have a relatively short lifespan in comparison to e.g. an industrial machine that may last 10 years continuous use (2 x 8 hrs shifts per day) before major rebuilds - that's 58,000 hours.
Of course given cars are generally used on short duty cycles (pre-COVID the average car still spent about 90% of its time parked up) it doesn't matter so much that their lifespan is perhaps 'comparably' short.
« Last Edit: February 17, 2021, 08:47:46 am by tom66 »
Online KE5FX
    • KE5FX.COM
« Reply #14 on: February 17, 2021, 08:55:12 am »
Interesting.  Where do they expect those cars to be sold?  It won't be to the US, the UK, Europe, or probably even China by that point.
Offline nctnico
« Reply #15 on: February 17, 2021, 09:32:28 am »
Yes it will. Politicians count ICE hybrids as electric cars as well. Car makers say they will switch to BEVs but they know very well that it just isn't affordable / financially interesting for everyone.
One of the problems car makers are facing is that small 3 cylinder engines vibrate a lot which reduces the comfort. The rotary design of LiquidPiston could be interesting to car makers to have a compact engine that doesn't vibrate so much. A power output in the 50kW to 90kW range is enough for a  hybrid drive system in a passenger car.
« Last Edit: February 17, 2021, 09:41:19 am by nctnico »
Offline Circlotron
« Reply #16 on: February 17, 2021, 11:21:40 am »
Poor surface to volume ratio in the combustion chamber which makes for high unburned hydrocarbons emission, just like a Wankel. Might be interesting running on hydrogen though. No HC.
Offline DenzilPenberthy
« Reply #17 on: February 17, 2021, 12:46:15 pm »
This is definitely in the same category as someone pouring resources into breeding better carthorses in 1900, or developing new thermionic valves in the late 50s. Utterly bonkers.
Offline nctnico
« Reply #18 on: February 17, 2021, 04:15:18 pm »
If you look closely at the video you'll see that that isn't the case. The claim is that it is opposite of the Wankel engine. If you look at the video you'll see that the burn chamber is closed off by the rotor giving a well defined (small) space in which the burn occurs.
Offline Benta
« Reply #19 on: February 17, 2021, 06:04:39 pm »
So put your money where your mouth is: buy some shares.
I'll refrain.
Offline nctnico
« Reply #20 on: February 17, 2021, 06:34:07 pm »
Why would I do that? It is just an interesting concept from a technical point of view.
Offline Benta
« Reply #21 on: February 17, 2021, 07:38:46 pm »
It's about as interesting as an over-unity machine.
Online KE5FX
    • KE5FX.COM
« Reply #22 on: February 18, 2021, 08:37:46 am »
I don't think so.  In the UK, for instance, they're talking about a cutoff date of 2030 for conventional vehicles and 2035 for hybrids.
By 2050, gasoline-powered passenger cars will be as common as horses are today.  Strictly an item for wealthy hobbyists and a very few specialists.  It's crazy to put any money into R&D of gasoline-powered engines at this point.  It's so pointless that it almost has to be a scam.  If KPMG disagrees, well.... we'll see, I guess.
Offline tautech
« Reply #23 on: February 18, 2021, 09:15:31 am »
LP has the advantage of great power density that's apparently even better than traditional NA rotarys however it's not clear if they have obtained an even reasonable operational lifetime from the LP design although if they are making that diesel version and with the compression ratios required for self combustion they need be reasonably strong.
From the promotional blurb it seems they can upsize the single rotor design to 1000hp so the need for a multi rotor design like the Mazda rotarys is apparently unnecessary.
Wonder if they respond well to turbocharging like the Mazdas ?
Offline nctnico
« Reply #24 on: February 18, 2021, 01:15:02 pm »
Seeing is believing. Nothing is cast in stone. There is a move towards the political right in Europe where the climate skeptics &deniers reside as well. In the end moving to new ways of transportation need to be affordable for the public and (unfortunately) the left parties fail misserably to show how to achieve that. Trump's 'Climexit' may not be the last one we see. In the end it is up to the voters.
« Last Edit: February 18, 2021, 01:51:31 pm by nctnico »
