Author Topic: internal tire pressure sensor on a road bike  (Read 3248 times)
Offline DiTBhoTopic starter
« on: August 24, 2023, 10:06:05 am »
How would you build an internal tire pressure sensor on a road bike?
it must be
- internal tire
- digital out
- able to measure { 5 .. 8 } BAR pressure
- installed inside the rim, under the inner tube
- or on the valve that is used to inflate the inner tube. In this case, it will be installed on a spoke?
- avoid Wifi, if it's possible
first problem is: how to communicate the data if the sensor is inside the wheel and this rotates on a hub?
how to decouple the wheel and hub by sending the data to the computer that I will install on the bike frame, approximately where the water bottle is mounted.
Mumble ...  :-//
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: internal tire pressure sensor on a road bike
« Reply #1 on: August 24, 2023, 10:10:53 am »
Have you looked at automotive TPMS modules ?
Day Job: Mostly LEDs
The following users thanked this post: amyk, DiTBho
« Reply #2 on: August 24, 2023, 12:07:15 pm »
thanks, good keyword to Google for  :D
Offline aeberbach
« Reply #3 on: August 24, 2023, 12:27:33 pm »
I've always found bike tire pressure to be pretty obvious to the rider, you can feel when you have too much or too little. Maybe it's different when the bike is heavier, carrying a motor and battery?
Software guy studying B.Eng.
« Reply #4 on: August 24, 2023, 12:30:25 pm »
If your valves are compatible with car tyres, theer are also external TPMS sytems that have a sensor in the cap
e.g. https://www.aliexpress.com/item/4000723547368.html
Offline Peabody
« Reply #5 on: August 24, 2023, 02:45:30 pm »
I just went through changing out the TPMS sensors on my ancient Civic.  The sensors were behind the valve, battery powered, and used WIFI.  I believe later cars use something like a Hall sensor on each wheel to sense rotation speed.  The speeds of the four wheels are compared over a period of time, and if one is spinning faster than the others, its pressure is assumed to be lower.  Perhaps something like that would work for a bike, but you would be dealing with very small differences.
Offline mendip_discovery
« Reply #6 on: August 24, 2023, 03:22:35 pm »
Could you measure the RPM of each wheel and compare the two and use that to inform you of a loss in pressure.
I remember Jean Louis Schlesser had a tyre pressure setup that allowed for adjustment while driving. I think it pumped air through the hub.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Offline Benta
« Reply #7 on: August 24, 2023, 07:37:37 pm »
On my bike, I just use my thumb. Takes a little practice, then you've got the feel.
Always on hand.   :-DD
« Reply #8 on: August 24, 2023, 07:51:52 pm »
yup! the bicycle computer module I am designing already has two RPM sensors, one on each wheel, so it's feasable at zero cost  :o :o :o
I will do the test on a Lemond Croix De Fer Road bicycle
I just have to be careful and not get distracted while I'm fiddling with the electronics
or else someone might steal it
Offline joeqsmith
« Reply #9 on: August 24, 2023, 07:54:23 pm »
Looks like they sell products for this.  Maybe something you could just buy.   My experience with a road bike has been if the tire pressure drops, its a flat.  I don't need a sensor.  Better to carry tools, patch kit, spare tube.....   I should bust out my old bike.   Maybe I could make it more than a mile before passing out.   :-DD
https://www.dcrainmaker.com/2018/04/hands-on-quarq-tirewiz-cycling-pressure-sensor.html
Better, control the pressure:
https://newatlas.com/bicycles/scope-atmoz-bicycle-tire-pressure/
« Last Edit: August 24, 2023, 07:56:52 pm by joeqsmith »
Offline abeyer
« Reply #10 on: August 24, 2023, 08:07:29 pm »
until you need to detach them to leave them installed on the tire.  :P
Offline Zero999
  • 0999
« Reply #11 on: August 24, 2023, 08:09:29 pm »
Road bike tyres need to several times the pressure as car tyres.
Offline joeqsmith
« Reply #12 on: August 24, 2023, 09:00:51 pm »
I was thinking you could sandwich a strain gauge between the rim and tube.  Small coil and some electronics.  Power it from a magnet mounted to the chassis.   Google search someone actually tried something similar.
https://gigazine.net/gsc_news/en/20130110-btps/
« Reply #13 on: August 24, 2023, 09:12:31 pm »
that's super interesting! thanks  :D
Offline thm_w
  • Non-expert
« Reply #14 on: August 24, 2023, 09:16:46 pm »
For live monitoring you are probably best off with that sram unit.
There are some non-live sensors as well, similar to the one joeqsmith linked above using NFC:
https://www.bikeradar.com/news/tubolito-tubo-mtb-p-sens-inner-tube/
https://bikerumor.com/exclusive-rover-psicle-wireless-tire-pressure-monitor-is-accurate-tubeless-battery-free/
Are you using TPU? https://www.bicyclerollingresistance.com/specials/tpu-inner-tubes
« Reply #15 on: August 25, 2023, 09:05:38 am »
p-sens-inner-tube/
Are you using TPU? tpu-inner-tubes
thanks for this info!
my 28" wheels are not tubeless as rims are not compatible with this technology, instead they use old school inner tubes (so, they are not TPU), but able to go up to 8 BAR of pressure!
TPU inner tubes look *very* interesting as advertised as made for speed and designed to offer the lowest rolling resistance possible.
The final bicycle will reach ~35Km/h on average on the road, with peaks of 50km/h!!!
Offline joeqsmith
« Reply #16 on: August 25, 2023, 01:18:28 pm »
That TPU link was very interesting.  Not that they make lighter tubes but that there is a concern over a few grams here and there.   :-DD
35Km/h is moving.  I remember when I started riding above 10MPH.  We lived in the hills.  I would ride about 20-30 miles after work.  Once we moved, it was all flat.  My average speeds were 18MPH.  I missed the hills, got bored and packed up the bike.    Now I'm an old fat man with an old heavy bike.
Offline tszaboo
« Reply #17 on: August 25, 2023, 02:21:27 pm »
I heard 4 BAR, that's what I use. A cyclist friend of mine said, you pump the tire until it blows up in your face and then you use the tire with just a little bit less pressure.
My car manual said 2.5 BAR.
« Reply #18 on: August 25, 2023, 02:53:13 pm »
how to save 200g from the inner tube with a lighter component, plus 400g off by removing the rear brake, so you can add +1200g on the wheel for the gearhub.
makes sense  ;D ;D
Offline joeqsmith
« Reply #19 on: August 25, 2023, 03:04:38 pm »
makes sense  ;D ;D
I could eat rice for a week  :-DD  That or just get back on the old bike.  My bikes added weight = better workout = more weight loss.   :-DD
I was running about 120PSI (8.3bar) in my road bicycle.
Offline BradC
« Reply #20 on: August 25, 2023, 03:14:45 pm »
I did that in my old Volvo. I used the ABS reluctors on each wheel to get a precise rotational velocity for each wheel. It requires an awful lot of averaging to make it viable and even then it wasn't great. Any time I wasn't driving in a dead straight line it was almost impossible to reconcile.
With the addition of a GPS receiver for self calibration it made an incredibly accurate and precise speedometer. In all honesty it was a good exercise in "seemed like a good idea at the time.
Offline Zero999
  • 0999
« Reply #21 on: August 25, 2023, 04:43:20 pm »
It depends on the size of the tyre. Larger tyres generally need a lower pressure than smaller ones. A road bike with thin tyres will need a much higher pressure than an off road bike with much larger tyres.
Offline tom66
« Reply #22 on: August 25, 2023, 04:48:18 pm »
This is how tyre pressure monitoring works in most European cars nowadays, with the exception of BMW and Mercedes who often fit run flats to their cars and so need to warn quicker of lower pressure due to the damage of running such a tyre low at high speeds.  I believe it's now a requirement for cars to include this function, even the basic Peugeot 108 I had for a couple of days had this function.  Since these cars already have ABS, it's almost free to include - just some software and an indicator light to flash the tyre icon on the dash.
The system is quite reliable.  In my past two cars,  it has detected punctures quickly enough.  Once, it was fooled by a particularly poor road surface (warning briefly of a possible loss of pressure, but removing the warning after 10 minutes.)  The system does require you to 'calibrate' it from time to time, if it does detect a low tyre, you reinflate all tyres to the correct level then press 'SET'.  I would guess even perfectly balanced tyres have some variation in road speed despite best efforts so a calibration allows this factor to be compensated for.
Offline tridac
« Reply #23 on: August 25, 2023, 05:40:43 pm »
One way might be to put a height sensor on the wheel bearing end of each suspension arm or fork, as the ride height will be lower if the tyre pressure is down. Obviously some noise filtering needed, but could be cheaper and less complex than measuring tyre pressure. Ultrasonic pulse rangefinder tech perhaps ?...
« Last Edit: August 25, 2023, 06:06:24 pm by tridac »
Test gear restoration, hardware and software projects...
Offline joeqsmith
« Reply #24 on: August 25, 2023, 08:50:36 pm »
Looks like there was a kickstart for one.   The comments are worth reading to get some different perspectives.
https://hackaday.com/2020/12/06/no-battery-pressure-sensors-for-bike-tyres/
