How would you build an internal tire pressure sensor on a road bike?
it must be
- internal tire
- digital out
- able to measure { 5 .. 8 } BAR pressure
- installed inside the rim, under the inner tube
- or on the valve that is used to inflate the inner tube. In this case, it will be installed on a spoke?
- avoid Wifi, if it's possible
first problem is: how to communicate the data if the sensor is inside the wheel and this rotates on a hub?
how to decouple the wheel and hub by sending the data to the computer that I will install on the bike frame, approximately where the water bottle is mounted.
Mumble ...
