Pretty much standard procedure in Oz!
I've had my moments,like rebuilding a SMPS unit in a Sony Picture Monitor.
The rectifiers on the secondary side had gone up in smoke & burnt big holes in the board.
Most of the rest of the board was uncooked.
The original rectifiers had two diodes in a fairly small package,& if not unobtainium,were one of the few things Sony couldn't get for us within a couple of days.
In the TV studio store,I found some small round PCBs which had been meant for some forgotten project.
Luckily,they had just about the right track configuration to fit two discrete diodes on.
Epoxied them in place in the (cleaned out ) holes. made the external connections,fixed the other faults,turned it on,& "Bob's your Uncle!" away it went.
In another case,an Electrohome Pix Mon cooked a Bi-Polar Electrolytic cap used in the "Boost HT " circuit.
Modern BP electros we obtained had too high ESR & cooked in minutes.
We ended up with a "Christmas tree" of Polyester "greencaps"---this became the standard fix.
LGT TV Transmitters had some "unobtainium"special ICs,which cooked up regularly,& the French were a bit "laid back" about sending spares to "Australie".
The boys made a small board piggybacked on a DIL plug to replace them.
I wasn't involved in making them,but I saw them in service.
In one place,a Thomson 10kW TV Transmitter's 32V supply for the transistor PA's croaked,& required special parts to fix it.
As luck would have it,there were some NEC 28v TRPA power supplies around,which were "tweakable" enough to get to 32V.
One of these was mounted in a box,sat down alongside the Thomson,with input & output cables jury-rigged.
It ran the Thomson for months!
I was again,only peripherally involved.
