Author Topic: Invention of the day: The banaligator  (Read 1870 times)
Online RoGeorgeTopic starter
« on: November 07, 2024, 12:04:28 pm »
Tadaaam!!!  Proudly presenting ... [drumroll] ...  The Banaligator!  8)
Take a thick paperclip, cut in two places to get 3 pieces of U shaped paperclip wire of different heights.
Solder those inside the tail of an alligator clip, to form a 4mm banana plug.
Found it to be very practical when attaching unterminated wires to the power supply.
« Last Edit: November 07, 2024, 12:09:23 pm by RoGeorge »
The following users thanked this post: 1001, schmitt trigger, BILLPOD
Online coromonadalix
Re: Invention of the day: The banaligator
« Reply #1 on: November 07, 2024, 12:40:29 pm »
hurry go get a pattent for this, you'll loose millions ...   :-+
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #2 on: November 07, 2024, 12:47:03 pm »
If you unscrew the binding post a little bit there is already hole to put a wire in on all of my TE with binding posts.  ;)
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: November 07, 2024, 12:52:40 pm »
Day Job: Mostly LEDs
Offline tszaboo
« Reply #4 on: November 07, 2024, 01:07:31 pm »
I have nothing else to add.
The following users thanked this post: vk6zgo, tom66, Siwastaja, Gregg, RoGeorge, woody, Nominal Animal, abeyer, RJSV, 5U4GB
« Reply #5 on: November 07, 2024, 01:08:58 pm »
Yes, but the banaligator would be faster and easier at attaching wires.
Side note, the binding posts in the Rigol DP832 power supply I have are notoriously bad.
https://www.eevblog.com/forum/testgear/wires-connected-without-banana-to-binding-posts-(rigol-dp832-power-supply)/msg5700041/#msg5700041  So far I had to use them only with banana terminated wires (even so, the banana hole in the red binding posts is smaller, some banana plug brands do not fit in the binding posts for plus, but they fit in the binding posts for minus  >:()
Except this time I've run out of bananas, tried to DIY a few more, and that's how I've accidentally arived to solder pieces of paperclip wires on an alligator.  The intent was to cut away the alligator jaws and solder a wire instead, only to realize it would be easier to leave it just like that, a banana with jaws.  ;D
« Last Edit: November 07, 2024, 01:11:31 pm by RoGeorge »
The following users thanked this post: schmitt trigger, Ground_Loop
Offline NE666
« Reply #6 on: November 07, 2024, 09:45:47 pm »
It would also likely be faster at blowing fuses and/or output stages too.
Online coppercone2
« Reply #7 on: November 07, 2024, 10:06:52 pm »
You should just buck up and fix your power supply before you get hurt having dodgy interconnects everywhere
https://www.digikey.com/en/products/detail/pomona-electronics/3760-3/736552
a few DIY special use adapters is one thing, but they should not be sticking out of your power supply in force
Online coppercone2
« Reply #8 on: November 07, 2024, 10:20:19 pm »
I just bought $160 of pomona and similar products because this thread scared me
The following users thanked this post: Geoff-AU
Online Analog Kid
« Reply #9 on: November 07, 2024, 11:09:50 pm »
Pomona? That shit's good but expen$ive!
Offline shabaz
« Reply #10 on: November 08, 2024, 12:34:49 am »
Wago are way ahead of you
https://uk.farnell.com/wago/51174966/plug-4mm-cage-clamp-red-pk5/dp/1283539
(Attachment Link)
Some action photos.
They work well with quite thin wires too, very handy when quickly trying things out.
I'm not using many (any) red/black in the photo because those are frequently sold out.
I also like the Deltron banana plugs (553 series) because they are about the cheapest reasonable quality plugs around for general use. Unless I need something higher-performance, I use those because they are extremely low-cost, have a screw terminal (so can even be easily reused at a pinch) and support stacking.
Offline jonovid
    • JONOVID
« Reply #11 on: November 08, 2024, 03:12:02 am »
just another  :-\ plug adapter to be copied & coming to AliEx soon  :popcorn:
Hobbyist with a basic knowledge of electronics
Offline shabaz
« Reply #12 on: November 08, 2024, 03:56:15 am »
Similar-ish functionality ones are already there.
They don't look all that great, though! (Although, to be fair, even the Wago ones visually look flimsy, but they perform fine.)
I prefer the Wago banana-end style over that AliExpress one, however (i.e., convex-bent steel wire in the shaft).
The following users thanked this post: porter
Online coppercone2
« Reply #13 on: November 08, 2024, 04:11:39 am »
this is an old concept I am sure people soldered speaker terminals to a banana connector before for convenience. I almost did many years ago but my speaker terminal was very low quality meant for super shitty panel mounting, long before 3d printers were popular
Offline shabaz
« Reply #14 on: November 08, 2024, 04:40:52 am »
I didn't think of that before, but it's a good point. The lever terminal on the banana plug is really not much different to the ones that were on the back of audio amps.
Online coppercone2
« Reply #15 on: November 08, 2024, 06:44:53 am »
maybe no one ever did it because when you take that apart you really doubt that its a good idea when you see the actual part :D
Usually you think "I can't believe that works" and "I can't believe they sold that" and "I can't believe I bought that"
Online coppercone2
« Reply #16 on: November 08, 2024, 06:46:23 am »
A wiring spring, like those in old electronics kits
It is basically a static structure at that point without any lever, pin or other mechanical jibba jabba that can cause problems. The alligator clip is a complex machine in comparison.
If soldered to a banana connector or shaped to be compatible with one it should make for a easy wire interconnect.
I think rogeorge can do better then make over complicated adapters
I believe the paper clip by itself can make a good interconnect so long its plated, shaped and tempered properly in the right places
« Last Edit: November 08, 2024, 06:57:07 am by coppercone2 »
Offline JXstaystonight
« Reply #17 on: November 08, 2024, 08:18:55 am »
Such a creative solution, RoGeorge! The banaligator seems super handy for quick setups. It’s impressive how a little ingenuity can solve everyday challenges. Just curious, have you tested its long-term durability?
« Reply #18 on: November 08, 2024, 09:13:14 am »
Thank you.
Not tested, only found that combination a couple of days ago.  Might need an isolation sleeve, too, as it was pointed out (a large shrink tube anchored to the alligator screw would do it).
Meanwhile I was looking for an even simpler way to DIY a banana connector to casual wires.  After all, alligators and bananas are middle-man pieces of metal.  Would be better to connect the strands of the wire directly to the binding post.  The sideways hole at the bottom of the binding post is one way to do that, but not very practical.
So I am looking now for methods to DIY a banana out of the copper strands of the wire itself.  The idea is to use a round wedge to press the wires against the inner walls of the 4mm hole inside the binding posts.  Pieces of round wood make a good wedge (tried chopsticks, toothpicks, matches, a twig, etc.).  Maybe not the most elegant, but very firm contact.
Another way would be to use the sleeve from a cable of just the right thickness, and to bend back the strands of the wires, something in the style of second DIY banana from the right:
Has to be something made out of common items, dirt cheap, and no longer than a minute to make.
Still looking for other ways to quickly and reliably plug a cable without using a banana.  Has to be something that can accommodate with slightly different diameters of the binding posts holes, too, like the faulty ones in my DP832.  Not sure which model will win in the long term.
« Last Edit: November 08, 2024, 09:20:25 am by RoGeorge »
Offline tszaboo
« Reply #19 on: November 08, 2024, 09:21:04 am »
I have two pairs of spring loaded banana connectors for quick wiring. This wago copycat looks interesting though, and I haven't seen it before thanks for posting.
The following users thanked this post: shabaz
Offline Nominal Animal
« Reply #20 on: November 09, 2024, 09:42:14 pm »
As an aside: am I the only one that parses the term intuitively as banal-igator?  Perhaps it is just my ugly personality, though.
« Reply #21 on: November 09, 2024, 10:17:43 pm »
Even so, still not as fun as the English word "therapist".
Online Analog Kid
« Reply #22 on: November 09, 2024, 10:23:43 pm »
Heh; like "cow orker". You know, the person at the desk next to yours.
Offline flipper
  • Definitely eti, unlokia, glossywhite, iamwhoiam
« Reply #23 on: November 09, 2024, 10:53:31 pm »
Aka “Psycho, the…”
« Reply #24 on: November 10, 2024, 12:24:41 am »
A therapist is not someone who has non-consensual sex with your mind, though.  Pity "mind blown!" is off by one base.
I particularly like therapistfinder.com: I know it is just two words, but I always see three.
