Author Topic: IP67 DB9 (D-sub9) Male to Female connector?  (Read 1373 times)
Offline Martin FTopic starter
« on: February 02, 2020, 07:23:09 pm »
Hi all,
We're looking to create an IP67 enclosure box for our product.
For this purpose, we would like to insert our existing product inside the IP67 and connect the two product DB9 female connectors to two IP67 DB9 male connectors in the box - see attached Enclosure.png illustration.
To do so, we're looking for something ala below, but waterproof:
https://www.google.com/url?sa=i&source=images&cd=&ved=2ahUKEwjE08ixyrPnAhXkmIsKHdkIC0cQjRx6BAgBEAQ&url=https%3A%2F%2Fwww.ebay.com%2Fitm%2F10Pcs-RS232-Serial-Port-9-Pin-DB9-Connector-Female-Male-Solder-Soldering-Plug-%2F372910623763&psig=AOvVaw2EUQIE_WWJn5s8pxiGJeoK&ust=1580757401104770
Our challenges is that we're unable to find any IP67 "straight through" DB9 adapters out there. Anyone who has any suggestions/ideas for this?
Any suggestions for this?
Best,
Martin
Offline TassiloH
Offline Tomorokoshi
Re: IP67 DB9 (D-sub9) Male to Female connector?
« Reply #3 on: February 02, 2020, 07:56:31 pm »
Manufacturer's pages:
http://www.assmann-wsw.com/us/en/products/connectors/water-proof-parts/detail/1861728/
http://www.assmann-wsw.com/us/en/products/connectors/water-proof-parts/detail/1861692/
https://www.conec.com/catalog/en/ip67-d-sub-connectors/ip67-d-sub-standard-high-density.html?a0003=1700&a0006=1869
https://www.edac.net/products/waterproof/28
https://b2b.harting.com/ebusiness/en_us/Interface-connectors-D-Sub-Subminiature-D-connectors-Cable-connector-Connector-IP67/389310?search=true&page=0
https://www.molex.com/molex/search/deepSearch?pQuery=q%253D*%253A*%2540fq%253Dcollection%253Aimpulse%2540fq%253Dcollection%253Aimpulse%2540fq%253Dcollection%253Aimpulse%2540fq%253Dcategory%253A%2522D-Sub%252BProducts%2522%2540fq%253Dproductcategory%253A%2522D-Sub%252BConnector%2522%2540fq%253Dtype%253A%2522Standard%252BDensity%2522%2540fq%253Diprating%253A%2522IP67%2522%2540fq%253Dorientation%253A%2522Straight%2522&currentQuery=circuitsloaded%3A9&origin=_l1stv13w
« Reply #4 on: February 02, 2020, 08:05:15 pm »
Thanks a lot!
The one from TassiloH looks quite spot on as it's got "plug & play" connectors on both sides, rather than e.g. a connector to fit on a PCB. If you know of other connectors of this type, I'd be happy to see them as well.
Thanks again.
Best,
Martin
