Author Topic: Is Banggood trolling?  (Read 6843 times)
Offline chartleTopic starter
« on: November 06, 2015, 12:34:16 am »
« Last Edit: November 06, 2015, 12:36:19 am by chartle »
Offline EEVblog
Re: Is Banggood trolling?
« Reply #1 on: November 06, 2015, 12:48:51 am »
As an aside, I've had countless people from Banggood want to send me stuff for review. A new name every week it seems...
Offline Macbeth
« Reply #2 on: November 06, 2015, 01:04:10 am »
Under new arrivals
http://www.banggood.com/DIY-Prototype-PCB-Board-Simple-Electronic-Mini-Clock-Kit-p-1010866.html  :)
Maybe if it had more wires.
Plenty of wires - all the bridges under the proto board.
I can't see the problem - it costs pocket money and is considerably more than the tat we used to get pasted to the cover of Everyday Electronics with a tiny piece of veroboard in the '80s. (This is in the old dart - 'strayans apparently got proper PCBs with their mags)
Why this one even looks like it could have a "towers of hanoi" minigame with the LED display it comes with!  :-DD
Having said that, I would be surprised if it even comes with some assembly instructions, even in chinese!
ETA: I just looked and it has plenty of documentation including source code.  :-+
« Last Edit: November 06, 2015, 01:09:01 am by Macbeth »
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #3 on: November 06, 2015, 01:25:39 am »
Offline Dongulus
« Reply #4 on: November 06, 2015, 01:33:57 am »
Avoid bringing this to school if you live in Texas.  ;)
Offline crispy_tofu
« Reply #5 on: November 06, 2015, 01:41:41 am »
According to the list, it has 'several wire', which should be enough...  :-DD
I wonder why they're using a 4-pin header when only 2 of them are being used for power, is it cheaper?
« Reply #6 on: November 06, 2015, 04:12:50 am »
Glad someone else got the joke.
Just seems too coincidental.
« Last Edit: November 06, 2015, 04:25:21 am by chartle »
« Reply #7 on: November 06, 2015, 04:29:40 am »
I was thinking of sending one to you but without being able to add a note to the package not sure you would get the connection and wasn't going order one, have it sent to the US of A and then send it back over the Pacific.
« Last Edit: November 06, 2015, 11:45:03 am by chartle »
Offline Stonent
« Reply #8 on: November 06, 2015, 05:41:22 am »
Well his parents refused to let the police release the information to the public and then they moved to Qatar so I guess we'll never know what happened.
Online Ian.M
« Reply #9 on: November 06, 2015, 05:57:44 am »
Hmmm . . . . .
A 24x10 matrix board, a 8051 based MCU that supports serial programming with a simple TTL level cable, a 4 digit LED with a few extra indicators, three switches, a beeper and a 4 way header, all for about $5   Mount the display off the board edge to free up some space and you've got the basic student hardware for an introduction to microcontrollers course.
Offline FrankBuss
    • Frank Buss
« Reply #10 on: November 06, 2015, 06:31:51 am »
Right, and the source code has even comments. Ok, is is in Chinese, but should be no problem, it is an interesting language that everyone should learn :)
The MCU might be interesting for other projects. But I can only find it on discontinued parts seller websites and on Aliexpress, for $1 for one piece. A similar PIC can do the same and is cheaper, but then you need a programmer.
Offline coppice
« Reply #11 on: November 06, 2015, 06:55:36 am »
Chinese comments are no problem, but using GB2312 encoding for them? In 2015? This really isn't acceptable.
Offline chickenHeadKnob
« Reply #12 on: November 06, 2015, 06:57:19 am »
If you route power/ground to pin 1 and 3 then you apply a reversed cable dave jones style  all you get  is a no-connect, for safety no bombe smoke surprise!
« Last Edit: November 06, 2015, 12:25:29 pm by chickenHeadKnob »
Online Ian.M
« Reply #13 on: November 06, 2015, 07:01:52 am »
There are many better MCUs , but academia still seems to be very fond of the 8051.  Add a budget USB <=> TTL serial board, a few extra components  and a small box (maybe a modded VHS tape case), and you've got a very portable $10 per head student kit.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #14 on: November 06, 2015, 07:07:14 am »
Interesting name.
Offline FrankBuss
    • Frank Buss
« Reply #15 on: November 06, 2015, 07:22:55 am »
For students a more modern system would be better, with an ARM CPU. There are many dev kits for less than $10, like the STM32F0308DISCOVERY, that are much more powerful than a 8051. But a single MCU which can be programmed with TTL serial might be still useful. I like PICs, because I can program it and use it in a breadboard, without the need for an additional external dev kit.
Offline Stonent
« Reply #16 on: November 06, 2015, 06:18:26 pm »
Interesting name.
Sounds like a place in Thailand to pick up a companion for the evening.  :-DD
