Author Topic: Is Dave's "I only give negative feedback" design original?  (Read 6696 times)
Offline jmc2000Topic starter
« on: December 17, 2014, 05:25:37 pm »
I love Dave's tee-shirt design, "I only give negative feedback", but I was under the impression that he was the first to use it via an op-amp. Yet a quick Google shows that there are some others using a very similar design:
http://www.amazon.com/Society6-Negative-Feedback-Clock-Tshirtbaba/dp/B00NAD7XXQ
http://baggout.com/product/Myntra-Women-s-I-Only-Give-Negative-Feedback-Black-T-shirt-Myntra/1038870
Regards,
JMc
Offline billcourtis
Re: Is Dave's "I only give negative feedback" design original?
« Reply #1 on: May 30, 2015, 09:56:56 am »
What is your point dude? "I only give negative feedback design is not patented. The t-shirt is not just available on these two sites but available everywhere
http://www.spreadshirt.de/i-only-give-negative-feedback-t-shirts-C4408A20819420
http://www.goodsearch.com/24tee/coupons
http://www.couponsmonk.us/coupon/t-shirt/
These sites are selling it for just $16 at discounted price. Unless the design is patented or copyrighted everyone can twist or copy the design.
Offline codeboy2k
« Reply #2 on: May 30, 2015, 12:24:11 pm »
oh, haiz.. has you gotz t-shirtz ?
Offline EEVblog
« Reply #3 on: May 30, 2015, 12:51:14 pm »
I was working at Altium at the time, the idea came at the lunch table. I then hand drew the circuit and scanned it in.
Didn't even look to see if anyone else had done it, not that I cared or it mattered.
I'm absolutely sure it's not original, it's just too obvious a play on words.
Offline codeboy2k
« Reply #4 on: May 30, 2015, 01:38:46 pm »
I'm not a lawyer, but the design is likely already your copyright, and depending on your laws probably implicit and you don't have to "register" anything. It's your own original design, placing the image next to the text in a specific location and manner and font face, size, colour, etc... and that is the copyright you probably already have on it.
If the other t-shirts change it up a little, different font, different line styles, different graphic, then it's probably ok for them to do it.
The text or the schematic cannot be copyrighted in most jurisdictions.
The text can be trademarked as part of your blog, if you wanted to go that far with it. And if you do, you have to make the enforcement effort, or it's not yours anymore.
« Last Edit: May 30, 2015, 01:42:36 pm by codeboy2k »
Offline RickBrant
« Reply #5 on: June 16, 2015, 11:58:19 pm »
While on this subject... I'd like to use the phrase and design on a badge hanger ribbon.
What's a badge hanger ribbon? It's a ribbon that you stick to the bottom edge of a convention membership badge, as shown in the "cover photo" here: http://www.pcnametag.com/ The thing that says "speaker" is what I'm talking about. The visible area is an inch high by 4 wide (25 x 100 mm), with the printable area a bit smaller.
In recent years at sf (science fiction) cons there has been a trend for people to get these made with all kinds of amusing sayings, much like you'd have on a T-shirt. It's not uncommon to see people with two, three, or twelve or more of these things in a long chain hung off the badge. Many of the come from the dealers' room - some dealers pass them out for free (as a way to get people to come to their tables); other fans just have them made, wear them, and pass them out when asked about them.
So anyway, I thought your slogan and design (I know, you disclaim it above, but it's associated with you now) would be perfect for declaring myself as a sometime EE and full-time eevblog fan.
Yes, I've ordered a shirt, but one can't wear the same shirt every day.
I've attached a GIF of the workup I did (originally in Visio). Whaddaya think? By the way this is a foil stamping process and there are severe limits on resolution; the smallest line weight they want to see is 1 pt, and 2 pt is recommended (most lines here are 1.5). The colors shown here are probably not final.
« Last Edit: June 17, 2015, 04:39:48 pm by RickBrant »
"banging meter needles into stop pins since 1965"
Offline Galenbo
« Reply #6 on: June 18, 2015, 06:50:24 am »
I would definitely buy one if it had the IEC resistor symbols.
Maybe just make my own, copypaste.
« Last Edit: June 18, 2015, 06:51:58 am by Galenbo »
If you try and take a cat apart to see how it works, the first thing you have on your hands is a nonworking cat.
Offline codeboy2k
« Reply #7 on: June 18, 2015, 07:39:46 pm »
You should get rid of that wonky, loopy, Rg resistor trying to go down when there's no room for it.
do it like this instead:
Offline RickBrant
« Reply #8 on: June 19, 2015, 07:15:24 pm »
Sigh, everybody's an art critic :)
Good point, but it's too late now. I'll try that mod if I reorder.
