Author Topic: Has anyone worked with MEMS resonators for timing?  (Read 3475 times)
Offline DJPhilTopic starter
« on: September 21, 2010, 10:43:46 am »
I was just poking around the wonderful world of ceramic resonators and crystals, and saw a category for these at Mouser.
Most of the literature I can find about these is laid on pretty thick with marketing piffle, so I thought I'd ask around and see if anyone's worked with them yet.
Is anyone familiar with the basic benefits and drawbacks vs. quartz?
What sorts of projects would benefit from this technology?
It seems like MEMS will be the timing widget of choice when it gets better and cheaper. It seems like they're advancing at such a pace that it'll be hard to have good answers for these questions that are current or will last long, but I think we'll all start hearing more about these soon.
What do you folks think?
Offline Zero999
  • 0999
Re: Has anyone worked with MEMS resonators for timing?
« Reply #1 on: September 21, 2010, 10:49:54 am »
I've never heard of it before.
I Googled it and found this article.
http://www.sitime.com/news/articles/mems_manufacturing.pdf
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: September 21, 2010, 01:27:45 pm »
I think teh major benefit is they are made of silicon, and so can integrate oscillators and dividers on-chip, and can be packaged in conventional plastic packages instead of hermetically sealed metal/ceramic.
I think they are also more resiliant to shock and vibration.
Day Job: Mostly LEDs
Offline Zero999
  • 0999
« Reply #3 on: September 21, 2010, 02:08:44 pm »
I suppose in future there will be microcontrollers with clocks more accurate than today's crystal oscillators without any external components.
Offline JohnS_AZ
    • About.me
« Reply #4 on: September 21, 2010, 02:13:02 pm »
They would also be easier to temperature compensate at the silicon level ... ie. sensor on the same substrate.
I'm either at my bench, here, or on PokerStars.
« Reply #5 on: September 21, 2010, 03:36:48 pm »
Microchip already do one with 0.25%  onboard RC OSC to allow USB with no resonator. Many now do 1% which is fine for serial comms.
Offline Zero999
  • 0999
« Reply #6 on: September 21, 2010, 04:50:49 pm »
0.25% is very poor compared to a piezo crystal, to put is into perspective, if one used such a MCU to build a clock with, it could loose or gain 3 minutes and 36 seconds per day which is +/- 21h 54m 54s per year.
« Reply #7 on: September 21, 2010, 05:18:39 pm »
Absolutely - there will always be apps that need crystals, or MEMs once they get good enough, but RC oscs are already eating into ceramic resonator, and low-end Xtal territory.  Once you get accurate enough for UART and USB using RC, the number of apps that need the increased accuracy of a crystal reduces significantly.
