Author Topic: Is there a meaning to colors on a transitor?  (Read 1316 times)
Offline RAPoTopic starter
« on: May 04, 2024, 12:06:47 pm »
I've got a whole collection of (unclassified) transistors.
I'll know that a dot on it can mean it is a matched pair.
But I also have transistors with several colours.
2163232-0
Do these colours have a meaning?
Offline Psi
Re: Is there a meaning to colors on a transitor?
« Reply #1 on: May 04, 2024, 01:01:43 pm »
Yes, its just the part number without the prefix, like 2N etc..
Colors are the same numbering as resistor colors. So red red red red would be 2N2222 etc...
https://www.instructables.com/From-Resistors-to-ICs-Color-Codes/
The following users thanked this post: RAPo
« Reply #2 on: May 04, 2024, 01:33:56 pm »
Ah, thanks. That makes the classification job easier. Topline color = first digit?
Offline Benta
« Reply #3 on: May 04, 2024, 08:54:49 pm »
Please show the other side of those transistors. The "colour-code" hypothesis is not really credible to me.
The following users thanked this post: wraper, RAPo
Offline floobydust
« Reply #4 on: May 04, 2024, 08:58:42 pm »
I know those coloured stripes as ranking for hFE or IDSS, not the actual part number.
« Reply #5 on: May 05, 2024, 11:29:57 am »
I think you are right. There are several A06's but they have different colours
2165419-0
« Reply #6 on: May 05, 2024, 11:31:27 am »
Do you have more info on which colour is used for which property?
Offline madires
  • A qualified hobbyist ;)
« Reply #7 on: May 05, 2024, 01:03:06 pm »
There are also BJTs with a dab on top to indicate the hFE range.
Offline Jeff eelcr
« Reply #8 on: May 05, 2024, 01:22:58 pm »
Many transistors were sorted for some spec, this is the way they were marked.
Whether they were marked by the transistor manufacturer or the company using them in manufacturing could be found out by asking the transistor manufacturer if possable, if not, I do not know of another way.
Although not as common this process is still used today.
Jeff
Offline RoGeorge
« Reply #9 on: May 05, 2024, 01:32:05 pm »
There was a time when Ge transistors where binned by beta, or by fT, and each category was a dot of different color.
Offline Benta
« Reply #10 on: May 05, 2024, 08:41:13 pm »
MPSA06... I remember those.
You have two different things here:
1: the thin horizontal stripes are production codes for lot/year/week whatever. Done by Motorola.
2: the "colour blobs" can be anything, but certainly not OEM.
Online Kleinstein
« Reply #11 on: May 06, 2024, 09:13:44 am »
Japanese JFETs (e.g. 2SK...) often come with IDSS grading via a color code, even with the same system used on different parts. With modern part the color may have changed to a letter code representing the color (e.g. R, O  Y GR BL ) not just for ordering.
The following users thanked this post: RAPo, Jeff eelcr
