Well, you can actually get stainless steel sheets cut to size fairly cheaply if you want a metal cover. What's also remarkably cheap per square meter is polyimide flex, the adhesive based Chinese one can be had at 12-14 bucks per square meter. If you want cheap silicone - simply as protection - and are less worried about ESD you can also go to the crafting and cooking supplies aisle.
