Author Topic: Isopropyl vs Isoproponol?  (Read 17447 times)
Offline djosTopic starter
« on: December 04, 2016, 09:37:13 pm »
G'day all, just curious as to what folks think (not starting a religious war I hope), I've always referred to my favorite cleaning alcohol as "isopropyl alcohol" but I've noticed recently that some folks (including Dave) refer to it as "Isoproponol alcohol".
I assume we are all referring to the same stuff, just wondering what preference others have when referring to it?
Offline IanB
Re: Isopropyl vs Isoproponol?
« Reply #1 on: December 04, 2016, 09:45:49 pm »
There are different names for the same thing. The common name is "isopropyl alcohol", while a more formal chemical name is "isopropanol" (not isopropanol alcohol), and a really precise chemical name is "propan-2-ol" (but nobody calls it that in real life).
Either isopropyl alcohol or isopropanol are fine, just pick whichever one is easier for you to say.
The following users thanked this post: tooki, djos
Offline rob77
  • Country: sk
« Reply #2 on: December 04, 2016, 09:46:18 pm »
Wikipedia
Isopropyl alcohol, also called isopropanol or dimethyl carbinol, is a compound with the chemical formula C?H?O or C?H?OH or CH?CHOHCH?. It is a colorless, flammable chemical compound with a strong odor.
« Reply #3 on: December 04, 2016, 09:47:20 pm »
Cheers, great explanation.
Offline stj
« Reply #4 on: December 04, 2016, 09:51:55 pm »
engineers just call it IPA.
more importantly, make sure it's atleast 99% pure.
stuff sold for medical use is often 70% or less, the rest is distilled water.
Offline Macbeth
« Reply #5 on: December 04, 2016, 09:55:05 pm »
Jesus H Christ, don't get me started on Di-hydrogen monoxide. As deadly as it is...
Offline Fsck
  • sleep deprived
« Reply #6 on: December 04, 2016, 09:59:20 pm »
it can also be 2-propanol.
"This is a one line proof...if we start sufficiently far to the left."
Online 2N3055
  • Country: hr
« Reply #7 on: December 04, 2016, 10:00:29 pm »
LOL... There was even a satirical web site preaching dangers of it...  :-DD
« Reply #8 on: December 04, 2016, 10:04:57 pm »
Good point, IPA is what I used to call back in the 90's as a HW Tech talking to other tech's, now I refer to it as Isopropyl Alcohol when telling my mates what to use to clean up their old 80's/90's computer PCB's if they've had a battery leak.
Offline lwatts666
« Reply #9 on: December 04, 2016, 10:08:31 pm »
While on a business trip to central India, we followed a tanker truck with a hand painted contents safety sign on the back. It stated that the contents on the tanker was "ISO_PAPAL_ALCOHOL".
The following users thanked this post: babysitter, tooki
Offline stj
« Reply #10 on: December 04, 2016, 10:09:14 pm »
you clean a pcb battery leak with vinegar.
Offline stj
« Reply #11 on: December 04, 2016, 10:10:44 pm »
it was blessed by god!  :-DD
« Reply #12 on: December 04, 2016, 10:11:27 pm »
I've heard of people using lemon juice as well, personally I use a proper PCB cleaner that is based on IPA but has some solvents in it too.
Offline Fsck
  • sleep deprived
« Reply #13 on: December 04, 2016, 10:13:32 pm »
using lemon juice just sounds really icky because I envision biological residue.
Why not just use bulk citric acid in that case? If you buy 20-50lbs at once, it's pretty cheap stuff and often used for descaling.
Offline stj
« Reply #14 on: December 04, 2016, 10:14:04 pm »
any mild acid works, your destroying the alkaline with it.
« Reply #15 on: December 04, 2016, 10:15:23 pm »
Yeah vinegar certainly sound preferable to me too.
Offline helius
« Reply #16 on: December 04, 2016, 10:39:49 pm »
There are two main ways that chemical names are formed. The older method is called "radicofunctional" and names a radical + a functional group. Alcohol is a functional group (the -OH moiety), and isopropyl is the name of the isopropyl radical. So it is written radical + function, isopropyl alcohol.
The newer method which is recommended by chemical societies is the "substitutive" method. This method is more general and can describe many chemicals that have no precise name under the radicofunctional system. The name consists of a base molecule (usually an alkane) and then is decorated with affixes according to the positions at which H atoms are substituted by other residues. There is a long list of rules about how exactly the substitutions are recorded, but in principle it provides a single, unambiguous name for any compound.
The base molecule is propane, and it has one of its H atoms substituted by OH at the 2 position. So it is named Propan-2-ol. The rules fill an entire book, but you can get the gist of it by browsing http://www.acdlabs.com/iupac/nomenclature/
"isopropanol" is completely nonstandard and fails to follow either set of rules.
Offline kxenos
  • Country: gr
« Reply #17 on: December 04, 2016, 10:42:11 pm »
Shouldn't it be Isopropylic Alcohol?
Offline IanB
« Reply #18 on: December 04, 2016, 10:46:43 pm »
No, that's not correct in English.
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #19 on: December 04, 2016, 10:47:09 pm »
BUT CAN YOU DRINK IT ?
Don't ask a question if you aren't willing to listen to the answer.
Offline IanB
« Reply #20 on: December 04, 2016, 10:47:47 pm »
You can drink anything. Should you drink it is another matter.
« Reply #21 on: December 04, 2016, 10:48:19 pm »
You can however you likely won't survive the experience. :D
Online wraper
  • Country: lv
« Reply #22 on: December 04, 2016, 10:49:56 pm »
Yes you can. The question is: can you do this more than one time?
« Reply #23 on: December 04, 2016, 10:59:32 pm »
Nice one, now some brave soul just needs to tell Dave to say isopropyl properly in future videos! :D
Offline imidis
« Reply #24 on: December 04, 2016, 11:00:25 pm »
Hmm, I don't believe I would dare try. I generally go with Isopropyl.
Gone for good
