Author Topic: Anyone here played around with fractal antenna for HF TV?  (Read 2539 times)
Offline nzoTopic starter
« on: December 23, 2011, 06:17:00 am »
I get notoriously bad TV reception out here in the countryside and surrounded by trees. The FreeView satellite is way behind the trees and they are not ours to cut down.
I'm wondering if there's anything to be gained (literally) by building a fractal antenna. I've just bought 2 rolls of adhesive copper tape to start experimenting. The only ones I've seen have been made from bent coat-hangers, so I figured...
No harm in trying eh?
Merry Christmas all!
Frogman: half man, half frog, but which half?
Offline Psi
Re: Anyone here played around with fractal antenna for HF TV?
« Reply #1 on: December 23, 2011, 11:22:07 am »
I know nothing about fractal antennas but i do have another idea.
Do you have anywhere on your land where you could setup a passive relay?
It's basically two directional antennas setup next to each other in a location that can see both the sat and your house.
One ant is pointed at the sat and the other is pointing at your main household tv antenna.
You run a short bit of coax between the two so they are directly connected together.
I cant say i've tried this with a TV signal, but it works with wifi.
It has the advantage of being completely passive and needing no power or electronics.
« Last Edit: December 23, 2011, 11:26:26 am by Psi »
Online Conrad Hoffman
    • The Messy Basement
« Reply #2 on: December 24, 2011, 01:10:52 am »
Is a fractal antenna like a fresnel antenna? I know people make those with copper tape on big sheets of Plexiglas or plywood. No idea if that's better than a dish.
Offline Lightages
  • Canadian po
« Reply #3 on: December 24, 2011, 02:29:34 am »
OK, so time for me to chime in here.
I am sorry to be the bringer of bad news, but fractal antennas offer no real advantage over any properly matched and tuned antenna. There have been a couple of nutters out there trying to push fractals as a more efficient antenna. What they might do, and the jury is still out, is provide a an antenna with a wider match across frequencies. Their claim to be as efficient as larger antennas but in a smaller package is normally "proven" using some pretty shaky testing procedures.
If you look up fractal antennas you wil find wikipedia has an article in it referring to the work of a Nathan Cohen. He is a regular nutbar who just happened to spend many hours arguing with people on usenet groups about antennas. He provided anecdotal evidence as proof for his designs being effective. Never once did he provide anything other than woowoo claims. If you want to believe that because he has a patent that the concept and design must be worthy, think again. The patent process is a broken pile of garbage. it does not meant that anything has any merit anymore.
Fresnel antennas use a method of destructive and constructive interference from waves passing though concentric circles of conductive material to form a hot spot at the "focus" They are not particularly efficient. They have nothing to do with fractal junk.
The connection of two antennas together with a proper impedance cable will result in a passive repeater, but...
The cable or connection between the two antennas will have loss and that should be taken into account. Also the two antennas will have their own losses. It is possible to make a passive repeater this way but it needs to use the least amount of interconnecting and least lossy wire/cable in between them. The best antennas to do this would be Yagis, or dishes, to provide the highest gain at each end.
In  the case of the original poster, it is probably best to make a high tower, or make a remote antenna and receiver and have it feed the house with the baseband signal using high quality coax and amplifiers.
There is no free lunch when it comes to things like this.
Offline Psi
« Reply #4 on: December 24, 2011, 03:03:23 am »
In some countries you require permission to erect anything over a specific height however there are sometimes loopholes/exceptions.
I remember one such loophole was flagpoles, dunno if it's still the case though.
I remember dad telling me of HAM radio geeks building antenna towers as flagpoles to get around the law :P
« Last Edit: December 24, 2011, 03:05:31 am by Psi »
