Author Topic: Jellybean list  (Read 20604 times)
Offline PhaedrusTopic starter
Jellybean list
« on: April 15, 2014, 10:17:01 pm »
In light of the discussion earlier about what is a jellybean, I wonder if people could post what ICs they consider to be jellybean parts
Some of the ones we got in that thread:
Op-amps:
LM324
LM358
TL072
Comparators:
LM393
LM339
Timers:
NE555
Transistors:
2n2222
BC548
PN2907
2N3904
2N3906
Diodes:
1N4148
1N914
1N400x
1N5817
1N5819
Regulators:
LM317
78xx
MC34063
Voltage reference:
TL431
Logic:
74HC series
« Last Edit: April 15, 2014, 10:40:03 pm by Phaedrus »
"More quotes have been misattributed to Albert Einstein than to any other famous person."
- Albert Einstein
Offline c4757p
  • adieu
Re: Jellybean list
« Reply #1 on: April 15, 2014, 10:28:55 pm »
Transistors:
PN2907
2N3904
2N3906
plus the MMBT version of all of them
Diodes:
1N4148 / 1N914
1N400x
1N5817-19
Voltage reference/shunt reg:
TL431
You could make a case for LM337/LM79xx and the 741 op amp, but they're not really all that common anymore. Same with most of the 4000 series, except a select few (like the 4051/2/3 analog muxes).
TL072?
« Last Edit: April 15, 2014, 10:32:20 pm by c4757p »
Offline rolycat
Re: Jellybean list
« Reply #2 on: April 15, 2014, 11:11:22 pm »
There have been quite a few similar lists compiled on the forum - this is a recent one.
It was also suggested in that thread that the completed 'jellybean' list could be added to the wiki - doesn't seem to have happened, though. Maybe the wiki needs more love...
Online David Hess
  • DavidH
Re: Jellybean list
« Reply #3 on: April 19, 2014, 04:18:06 am »
Op-amps:
LM324
LM358
TL072
I would also include at least the OP-07 for precision use since there are so many sources for it now and it is cheap.
Transistors:
2n2222
BC548
PN2907
2N3904
2N3906
I have replaced the 2N2222 and 2N2907 with the 2N4401 and 2N4403 which can also in almost all cases replace the 2N3904 and 2N3906 as well.
I would include a complementary pair in TO-225 packages for those times when a TO-92 will not cut it.
2N7000 (TO-92 N-Channel MOSFET)
2N3055
D44H11 and D45H11
Diodes:
1N4148
1N914
1N400x
1N5817
1N5819
I do not think there is any reason to have both the 1N914 and 1N4148.
I would include the 1N270 or a small signal schottky.  They make great baker clamps, protection diodes, and detectors.
I would include the 1N4937 as a general purpose fast recovery rectifier.
In general a higher voltage diode in the same series can replace all of the lower voltage ones and usually does not cost any more so there is no reason to include the 1N5817.
Regulators:
LM317
78xx
MC34063
LM317LZ (makes a good instant current source/sink)
LM337
78Lxx
79xx
79Lxx
Offline con-f-use
  • Country: at
Re: Jellybean list
« Reply #4 on: April 19, 2014, 10:21:57 am »
Temperature Sensors:
TC1047
TMP35 / TMP36 / LM35
TC77 (digital)
« Last Edit: April 19, 2014, 11:54:54 pm by con-f-use »
Offline mrkev
  • Country: cz
Re: Jellybean list
« Reply #5 on: April 19, 2014, 11:07:00 am »
Transistors:
2n2222
BC548
PN2907
2N3904
2N3906
Strange, I wouln't consider those as jelly bean, it's more common to use (at least here):
bc337, bc547, bc556; for more power bd139 and bd140; 2n7002 as mosfet
And just a bit more than a decade back, we were used to use old TESLA (communistic factory for el. parts), some have still full draws with those:
ksy21, kc507, kf507, kd502, etc...
Online David Hess
  • DavidH
Re: Jellybean list
« Reply #6 on: April 19, 2014, 07:42:31 pm »
Transistors:
2n2222
BC548
PN2907
2N3904
2N3906
I keep a stock of high beta transistors like the 2N5087 and 2N5088 around for when general purpose ones will not do but since their application is limited, I did not mention them.  For similar reasons I might leave the BC series intended for audio out as well.
Similarly I try to keep saturated switching or RF transistors like the MPSH10 and MPSH81 around.
Offline c4757p
  • adieu
Re: Jellybean list
« Reply #7 on: April 19, 2014, 07:45:33 pm »
Transistors:
2n2222
BC548
PN2907
2N3904
2N3906
PN2222/2907 and 2N3904/6 are very common here.
Offline SolarSunrise
  • Country: ua
  • Hi there!
Re: Jellybean list
« Reply #8 on: April 24, 2014, 10:47:16 am »
Why are people calling cheap and readily available parts jellybeans? Hmm outside US jellybeans are hard to find, and if you do, they cost a fortune!
Offline electronics man
Re: Jellybean list
« Reply #9 on: April 24, 2014, 03:37:04 pm »
They are. Readily available in the uk  and syes they are expensive
follow me on twitter @get_your_byte
Offline NiHaoMike
    • Facebook Page
Re: Jellybean list
« Reply #10 on: April 24, 2014, 04:55:20 pm »
The 3842/3843 and equivalents are common in switching power supplies.
Offline gareth
Re: Jellybean list
« Reply #11 on: June 04, 2014, 03:03:25 pm »
I've been looking for a small-signal jellybean p-channel mosfet without luck. I've been using a ZVP4424A which works but it's a bit expensive (ok, I'm a cheapskate!). So I have come here, metaphorical cap in hand, hoping that someone can suggest a better alternative or help me to improve my search abilities so that I can find it myself (teach a man to fish and all that). One of the attractions for me of Jellybean parts apart from price is the long lifetimes that they endure. I'm looking forward to building 555 circuits with my great-grandchildren!!
I have looked over the more obvious threads here and via google, so apologies in advance if this has already been answered and I missed it somehow.
I need to switch only a few mA by a 3.3v logic level from a MCU, for voltage measurement of a battery. The mosfet is used to avoid the (tiny) losses involved in a more straightforward resistor divider. Essentially I want to make the circuit in the attachment (from original design here: http://jeelabs.org/2013/05/18/zero-power-measurement-part-2/)
My ideal mosfet would be:
Low leakage when 'off' (is this what is referred to as Gate-Body Leakage?)
Cheap
Readily available until the end of time
Available in both through hole and surface mount
From my other research on the web I've looked at these candidates:
BSS84 - smt only
FDN338 - smt and can't find it on sale!!
So is there a part that fits all my needs? The leakage needs to be below ~200-300nA because otherwise I may as well use a resistor divider.
I've blogged about the application for this circuit and this question here: http://l0l.org.uk/wireless-sensors-overview/
Many thanks in advance.
Gareth
Offline calexanian
    • Alex-Tronix
Re: Jellybean list
« Reply #12 on: June 04, 2014, 07:15:03 pm »
I might add SD103 as the schotkey small diode and 1N34 just because if you need germanium its one of the only old school ones left in any sort of quantity. Also ltC1044/7660 charge booster. Used as a bias supply in jillions of LCD displays.
Charles Alexanian
Alex-Tronix Control Systems
Online David Hess
  • DavidH
Re: Jellybean list
« Reply #13 on: June 18, 2014, 11:22:15 am »
I searched for one but there is not even an inexpensive N-channel MOSFET which I find puzzling.  MOSFETs also tend to work poorly with logic level drive below 5 volts.
I like the germanium 1N270 myself but for a jelly bean small signal schottky diodes I would probably pick the BAT41 (low leakage and low capacitance) and BAT48 (high current).  They are all pretty expensive though compared to the 1N4148 and similar.
Offline dannyf
Re: Jellybean list
« Reply #14 on: June 18, 2014, 11:30:24 am »
Mine is simpler:
transistor:
2n5401/5551: analog / digital, high voltage / low voltage;
fdp3672: almost logic level.
irf540: I have a ton of it
irf510: the most unique mosfet in my view.
regulators:
AM1117, different flavors
TL431: cheap.
logic:
HC132: can do  anything
HC164: my goto shift register
timer:
12F675: program anything to it
diodes:
1n4148
bat54s: cheap
opamp:
tl072: tons of it
RF:
BF998: cannot beat
PN3563: tons of it
