Did you ever meet a panel with a dead backlight? I never.
I had 2 monitors failures in my life and both were processor board issues causing artifacts.
And both lasted well over 10 years.
Yes, I've fixed two of them and scrapped four more of them, one because the 65" panel cracked while we were lifting it out of the frame. It's very common with modern LED lit LCD TVs, it's actually the most common failure mode I've encountered. Look online for LCD TV LED backlight failures and you'll see lots of examples. Typically one or two LEDs will fail and that causes the driver to shut down after a few seconds.
The TV I'm currently using was less than 2 years old when the backlight failed and it was given to me. Another that I fixed was a similar age, that one was edgelit.
That's just the LED backlights, I've seen scores of worn out CCFL backlights. Often replacing the tubes isn't worthwhile because the plastic optics turn yellow from the UV. I took apart one panel where the diffuser sheets crumbled to bits they were so brittle.
