Author Topic: Placing SMD resistors by hand - what do you use?  (Read 7906 times)
Offline miceuzTopic starter
  • Country: lt
    • chirp - a soil moisture meter / plant watering alarm
« on: September 10, 2013, 10:07:19 pm »
Whenever I tear the plastic cover tape from the resistor reel tape, the majority of resistors end up on the table bottom up   |O. How do you deal with that?
The tweezers are not thin enought to get there and grab 0603 resistor. I've seen Mikes video on the topic - spilling them on paper and tapping it to randomize sorta works, but is not sufficient for me. Any thoughts?
Offline 8086
    • Circuitology - Electronics Assembly
Re: Placing SMD resistors by hand - what do you use?
« Reply #1 on: September 10, 2013, 10:09:05 pm »
If you tap the resistors on one edge with the tip of the tweezers they will flip over. I do loads of hand surface mount and it's not been a huge issue.
The tweezers aren't thin enough for 0603 resistors? Sounds like you need better tweezers. I don't have any problem with mine.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: September 10, 2013, 10:13:38 pm »
Vacuum pen (foot operated) is WAY faster when you have a few from each tape.
It's an even bigger advantage for polarised parts.
Day Job: Mostly LEDs
Offline MatCat
« Reply #3 on: September 10, 2013, 10:18:04 pm »
Get yourself some 5A tweezers!  Even if they fall down on the table upside down the 5A tweezers can easily manipulate them.
« Reply #4 on: September 10, 2013, 10:24:33 pm »
..but you still can't reliably pick direct from tape with tweezers - the gap isn't big enough
Offline MatCat
« Reply #5 on: September 10, 2013, 10:35:08 pm »
That is true, I usually just let them fall into a bin I have on my bench and tweezer them from there.
Offline David_AVD
« Reply #6 on: September 10, 2013, 11:41:09 pm »
We use the "stick the tapes down to a plate and use a vacuum pen" method as shown in Mike's video and that's working well for us.
Online nctnico
« Reply #7 on: September 10, 2013, 11:42:33 pm »
I have the Erem 7-SA tweezers. Today I used it for placing a couple of 0201 sized resistors (no, not metric). I keep components in small plastic boxes with lids so its easy to pick them up with tweezers.
Offline MacAttak
« Reply #8 on: September 11, 2013, 02:53:53 am »
Spend 45 cents more and buy twice as many, then just throw away the half that didn't land right-side-up.
Offline MatCat
« Reply #9 on: September 11, 2013, 03:01:57 am »
They are certainly cheap enough!
Offline komet
  • Shenzhen Retroencabulator Mfg. Co.
« Reply #10 on: September 11, 2013, 04:34:41 am »
Bang your fist on the table hard. I'm not kidding. It might not work if your bench is too solid.
Offline SparkysWidgets
    • Sparky's Widgets
« Reply #11 on: September 11, 2013, 05:25:12 am »
Mike is spot on,
I have a SMD soldering video where I talk a bit about this and link back to Mikes video where he showed me the ways :clap:
http://youtu.be/z7Tu8NXu5UA
I recently found some small reel stands that work very well now to a way to make them myself!
and if you are more into solder paste and reflow here is another video
http://youtu.be/DpgOYNB1Kng
  • Country: lt
« Reply #12 on: September 11, 2013, 05:54:16 am »
Can anyone recommend a vacuum pen with sucktion tips small enough?
Offline David_AVD
« Reply #13 on: September 11, 2013, 06:58:32 am »
I'd have to double check, but I'm pretty sure my guys use a hollow needle (end ground) with no cup.
Offline kayvee
« Reply #14 on: September 11, 2013, 07:04:49 am »
Correct.  This is the type you are looking for.
http://www.edsyn.com/index.php?Mode=piw&pn=EDN-K1
Offline JuKu
    • LitePlacer - The Low Cost DIY Pick and Place Machine
« Reply #15 on: September 11, 2013, 07:16:13 am »
Look harder.  ;) If you use a microscope (and with SMD, you really want to), you want needles with an angle in them. I don't recall where I got mine. Filing the end of a straight needle might also work, but I haven't tried. +1 for double sided tape and a foot switch.
http://www.liteplacer.com - The Low Cost DIY Pick and Place Machine
Offline kayvee
« Reply #16 on: September 11, 2013, 07:37:53 am »
Depends on the tool to place resistors and small caps. ;)
For quick and dirty, a good pair of tweezers.
For my knock-up XY table with vertical rotating hand operated head with footswitch vacuum, I used those listed.
Bigger IC's, yes a hand tool with angled shatf and cups.
Offline poorchava
  • Troll Cave Electronics!
« Reply #17 on: September 11, 2013, 07:44:08 am »
I just take them from the tape onto a jar lid upside down and then tap the lid gently. That's only because my workbench is very sturdy and it wont vibrate enough if i slam the table with my fist. For plasement i prefer XY-7-SA tweezers from Xytronic (or pointy curved tweezers anyway).
Offline Jon Chandler
    • Throw Away PIC
« Reply #18 on: September 11, 2013, 08:22:03 am »
Here's how I turned a thrift-store nebulizer into a vacuum pickup tool with about five minutes effort.  A large-bore hypodermic needle ground flat works well without a suction cup.
« Reply #19 on: September 11, 2013, 08:24:48 am »
For larger needles and cups for QFPs etc. buy one of the cheap, useless manual tools from ebay just for the tips
http://www.ebay.co.uk/itm/IC-SMD-Easy-Pick-Picker-Up-Hand-Tool-Vacuum-Sucking-Pen-/180673031279?pt=UK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET&hash=item2a10f3ac6f
These also make good donor pens for adding a tube for a proper vac pen.
For smaller sizes for picking 0603s and below, use stainless dispensing needles and bend them yourself.
