Author Topic: How about this dashboard symbol?  (Read 197 times)
Offline Zeyneb
« on: April 05, 2020, 08:25:42 pm »
Hi there,
I hope you like this post. So I have a car, a Peugeot 205 from 1995. And I decided to get the instrument cluster out to replace some indicatior bulbs. Also I took the time to fully document the wires going to the cluster. There are some repair manuals on this car but regarding electrical stuff they s*** hell.
My car is for gasoline fuel but the instrument cluster also has the ability to display some warning lamps regarding an diesel engine. For example: Water in fuel filter and a pre-heat active. There is also a pretty obscure warning lamp which didn't have a fitting mounted in the rear panel.
So I was able to make it lit by looking at the rear board. It looks like some laboratory glassware with a droplet. Do you know what this dashboard symbol means? It is in the top right corner of the fuel gauge.
Regards, Zeyneb
« Last Edit: April 05, 2020, 08:31:37 pm by Zeyneb »
Do not believe in miracles, rely on them!
Offline helius
Re: How about this dashboard symbol?
« Reply #1 on: April 05, 2020, 08:32:49 pm »
That is an oil temperature warning light.
PS. you need to resize your image to something that doesn't require a 30" screen to view (the image posted is 5312 × 2988 pixels).
