They could be the wires of a temperature sensor. As it is a single cell there is no balancing needed, which on multiple cell batteries leads to additional wires if there is no BMS in the battery itself.But it can still get warm or hot when charging/discharging and the device might cut off the process in that case.The battery on the picture is clearly not original for a JYETech DSO112A, so I guess you got this one from a phone or tablet and want to stick it in the DSO112A. If so you can most likely just ignore the two white wires.
