Author Topic: Keysight 34465A saving temperature settings  (Read 861 times)
Offline RobaroniTopic starter
  • Retired EE
    • Design Specialties
« on: January 06, 2022, 01:14:32 pm »
Is there a way to save my temp settings on the 34465A so I don't have to redo them every time I use my probe?
Thanks for the time and help,
Rob
Offline Dr. Frank
Re: Keysight 34465A saving temperature settings
« Reply #1 on: January 06, 2022, 04:34:34 pm »
Hi Rob,
that's easy.
Configure your 34465A to TEMP, and the sensor settings you need.
Then go to Utility - Store/Recall, select a name for your setting, and STORE STATE
Whenever you recall this state, it will exactly come up in this  configuration.
You can also make this setting your default boot setup by storing the configuration and setting the DMM to "Power on  - User defined". See manual for details, where /how to store this correctly.
Frank
« Last Edit: January 06, 2022, 04:37:30 pm by Dr. Frank »
  • Retired EE
« Reply #2 on: January 06, 2022, 07:11:10 pm »
Thanks Frank, appreciated.
Offline jonpaul
    • IEEE Spectrum
« Reply #3 on: January 06, 2022, 08:51:58 pm »
Bonjour, A fantastic meter!
In Utility you can configure the startup to default to factory, user OR to restore previous
(SHIFT) Utility>>store/recall>>power ON
Selections ...
LAST
USER DEFINED
Factory Default
Suggest LAST
Same applies to entire series 34461A, 34470A etc.
Bon courage!
Jon
An Internet Dinosaur...
