Author Topic: KVM cabling rj45 to ps/2 adapters - are brands interchangeable?  (Read 852 times)
Offline bcg
Does anyone know if the various Lindy, Aten, Avocent etc rj45 to ps2/vga adapters are interchangeable between brands?
Just got a good deal on a Lindy 32 port KVM and then nearly died at how much each adapter costs.
There are other brands to be had at 7x less the cost.
Wondering if anyone can share their experiences?
Thanks,
Brad
Offline SL4P
  • There's more value if you figure it out yourself!
Re: KVM cabling rj45 to ps/2 adapters - are brands interchangeable?
« Reply #1 on: August 18, 2016, 09:23:40 am »
From what I've seen, there are common 'standards' but not across all brands.
You're better having one known good cable set, then shopping around to see if you can match it.
The prices are eye-watering for the OEM cables!
Don't ask a question if you aren't willing to listen to the answer.
