I have a Bosch dishwasher with "Vario Speed" (funny, I wonder if the Siemens product is just a rebadge given the same name of the feature?) It advises that this can 'shorten' the cycle by up to 1 hour if it detects the dishes are only lightly soiled.
In order to do this, it uses a turbidity sensor, which you can see if you take the drain filter out - it's essentially an infrared source and a receiver, measuring the approximate opacity of the drain water. One of the first things a modern dishwasher does is a cold pre-rinse, before the tablet drops. This gets the majority of the surface dirt off the plates. The turbidity sensor then assesses the level of dirt and this causes the controller to adjust the wash profile.
This is one reason that not only is pre-rinsing dishes before you put them in the dishwasher unnecessary, but it can also make the dishwasher less effective at the actual cleaning process. Because the dishwasher makes a guess at how dirty the plates are and uses more or less heat to remove the remaining dirt. If you've essentially almost cleaned the dishes before putting them in, it will mispredict and you will be left with dirtier dishes, than had you not rinsed at all. I'd also question why you use a dishwasher in the first place because the idea is to make doing dishes less of a chore and if you're rinsing the dishes by hand it's not much more effort to wash them up too.
Since all modern dishwashers implement this - even on their most aggressive 70C setting - I can only guess that 'Vario Speed' is a marketing term, perhaps it allows it to shorten it by a bit more. But to get the EU energy rating, it pretty much needs this feature to work on the 'Eco mode' all the time. Yes, there is a European standard set of dirty dishes, with a precise amount of contamination to apply to each dish before measuring the efficiency of the machine.
