For testing purposes have roughly re-calibrated zero and gain for mid DCV ranges and it appears to be measuring OK and stable. Reference zener LM399H is spot on 7V and appears stable.
At this stage it looks like all it needs is detailed calibration. Can't find any reference in service manual for error "9 NOT CALIBRATED", not sure if 9 is some item number as there is no mention of ERROR 9 anywhere, and there is only one item in the ERROR log?
Intention is to use this meter in automated setup for low DCV, DCma and resistance where accuracy is not critical, 0.5% will be OK, so hopefully I can calibrate it against my very accurate HP 34401a.
I would still appreciate comments from people that are more familiar and experienced with 3457A.
Cheers.
