Speaking of LED lights, is there any suitable replacement bulbs that are LED that fit in "mini light" incadescent sockets? The ones that are in series where the bulb has a shunt so it closes circuit if it dies. I have a tree with them built in and they are burning out, and if too many burn out the whole string goes as they are getting too much voltage. I have yet to find suitable replacements, I tried different voltage ones but sooner or later the whole string just dies. Also, can someone explain this one? If I put a 12v rated bulb, it dies immediately, while the 3v one does not. Why would the higher voltage one die when the lower voltage one does not? Since I did not know the voltage originally I figured I would start with highest and work my way down but that did not quite work!
