Author Topic: LED drawer storage system  (Read 1649 times)
Offline StillTryingTopic starter
  • Country: Broken Britain
« Last Edit: August 05, 2020, 01:23:47 pm by StillTrying »
Online m98
Re: LED drawer storage system
« Reply #1 on: August 04, 2020, 10:07:23 pm »
How is this useless? It's a nice and simple beginners project, and could be extended to something quite useful. Type in your needed value and it lights up the closest combination of E12/E24 resistors.
The following users thanked this post: Zbig, ANTALIFE
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
« Reply #2 on: August 05, 2020, 04:42:13 am »
Offline Halcyon
  • Global Moderator
« Reply #3 on: August 05, 2020, 08:16:05 am »
What's wrong with a label?
The following users thanked this post: StillTrying
Offline tooki
« Reply #4 on: August 05, 2020, 09:19:23 am »
Not enough blinkenlights! More cowbell!
Honestly, while I don’t see the point in this thing from an end-product standpoint, it’s a great little project from a learning standpoint. I mean, few of us here need the projects we build. But that’s because need isn’t why we build them! :)
The following users thanked this post: ebastler
« Reply #5 on: August 05, 2020, 11:38:27 am »
Of course it's educational to build and maybe even novel or fun, but its totally useless to use.
What's wrong with just labelling the drawers 10k-16k,  18k-27k,  30k-47k. :palm:
« Last Edit: August 05, 2020, 01:30:38 pm by StillTrying »
Offline krish2487
« Reply #6 on: August 05, 2020, 01:13:14 pm »
So what happens if I put the resistances back into a wrong drawer??  >:D
You know the saying.. when you have a hammer....
If god made us in his image,
and we are this stupid
then....
« Reply #7 on: August 05, 2020, 01:29:02 pm »
All the LEDs flash red as a warning, with the correct drawer flashing green. >:D
If you think about it it's almost impossible to put new resistors in the correct drawer. :palm:
I don't think it's really finished without a camera and robotic arm, where you could just put the resistor(s) in front of it and the arm picks them up and puts them into the correct draw. >:D
« Last Edit: August 05, 2020, 06:27:38 pm by StillTrying »
Offline newbrain
« Reply #8 on: August 06, 2020, 09:20:46 am »
Here is the schematic to help me put SMD resistors in the right drawer.
It might have minor scalability problems, if you have more than one drawer.
Online Zero999
  • 0999
« Reply #9 on: August 06, 2020, 12:51:16 pm »
Here are some photographs of my resistor storage system.
« Reply #10 on: August 06, 2020, 02:12:58 pm »
"Here are some photographs of my resistor storage system."
I don't understand where do all the RGBW LEDs go. >:D
I've use exactly the same, like the one on the right with the other resistor values just scribbled on. I use the spare bit of foam near the handle to poke resistors into when I can't be bothered putting them back in the tubes. :-/O
Offline Red Squirrel
« Reply #11 on: August 08, 2020, 03:03:13 am »
I think it's a neat idea, but I'd want it to be more expandable.  I always thought it would be cool to setup a drawer system with some kind of backplane, each drawer has a bunch of dip switches you code so each one is unique and it plugs into the backplane when the drawer is pushed all the way.  Each drawer system also has it's own dip switches.  Everything is then interconnected together as one big system. You inventory all the parts into each drawer and when you want something it would tell you where it is.
But really it's probably easier to just label everything so you can find stuff without first looking it up on the computer.  I do want to come up with a modular system myself at some point and just mass build them.  The issue with the ones you buy is you can never get the same ones again down the line.  If I build it myself they will all be consistent and I would keep the plans/jigs to build more later.  What I have in mind is some kind of drawer system with a bunch of smaller boxes inside.  5x5cm 5x10, 10x10, etc could be common sizes and you can mix and match and move them around at will.
I really want to insulate my garage and convert to a shop, other projects just keep taking precedence but once I do that, I will make that box system one of my first wood working projects. I want to build jigs and stuff so I can churn these out like crazy.  Organize everything in them.
Offline ElektroQuark
    • ElektroQuark
« Reply #12 on: August 08, 2020, 08:24:55 am »
The system has some benefits, the bigger of all the no necesity to order resistors by value, you can store them in the next free spot and simply tell to the manager.
Offline kjr18
« Reply #13 on: August 08, 2020, 09:00:43 am »
You can always 3d print them, for example something like this: https://www.thingiverse.com/thing:4160638 or something like this: https://www.thingiverse.com/thing:3125601. Easy to make, easy to modify, and customisable.
« Reply #14 on: August 08, 2020, 06:15:39 pm »
Yeah I've seen that done too actually.  Would need to figure out what ends up being more expensive, wood, or 3D printing.  I do eventually want to get into 3D printing.  I just can't find any CAD programs that are actually decent to use in Linux, they're all super clunky and cubbersome and user unfriendly.    I just want to be able to easily click, type a dimension and snap lines and do other operations quickly and easily.  Drag, copy, move etc... all the cad programs in Linux make all these basic operations super cubbersome.   Was looking at Freecad and it's insane the amount of steps you need to do simple tasks.  I'll probably eventually just write my own.
Offline RenThraysk
« Reply #15 on: August 08, 2020, 06:38:45 pm »
Or each drawer has a PCB front where can solder one of the components. And when put the draw back in, the component is automatically detected/tested, and recorded with their location.
If had a BOM list on a computer, it'd light up every require parts draw, until its been open and closed.
