Order some 500mA slow blow fuse from RS, on received found the fuse were marked as 5A
instead of 500mA. Called RS, asked them to inspect the item before ship and they sent replacement few days later. Same issue.
Gave them a call again and asked them to check the lot again, finally get the right shipment today
The first 2 shipment were from the warehouse in France while the correct one is from Germany
