I bought OSRAM smart bulbs for my kitchen downlighters. The are GU4.5 / MR16 12V fittings. 12VAC lighting with transformers used to be all the rage, they are discouraged these days for many reasons.
I took my working IKEA 5W LED bulbs out and put my new OSRAM Smart+ in. Turned them on and the new lamp blinks once and then nothing. Tried 2 different bulbs in two different sockets. Same.
Took one of the bulbs to the lab and hooked it up to 12VDC. Worked perfectly.
Took the meter down to the kitchen lights and got a reading of 3.8VAC 0VDC. 50Hz.
I phoned my electrician. He's out with me now, talked me into switching to 240VAC GU10s.... for many reasons. So he is off buying modules to convert them.
I am still puzzled as to how there is only 3.8VAC. I thought it was my measuring as it was really fiddly to get probes on the tiny pins and I ended up using some pin headers on croc-clics.... janky AF. So while the spark had them out of the cieling and the "12V" output exposed, he put the meter on a different one again and it read 6.2VAC.
I thought there was a single transformer for all 5 lights, however there is a driver per lamp.
How can they ALL be putting out less than half the spec voltage? The LED lights work.
Is it likely that using 5W LED bulbs with transformers designed for 50W halogens has broken them?
I don't know how old these transformers/drivers are, but they do indeed say 11.5V AC 50Hz 20-65VA.
It's that "20-65VA". Is the minimum important? If I am not pulling 20VA through them are they likely to not produce full voltage?
Hopefully this evening I shall have 5 of them to play with and find out.
