So we are talking IEC C13 power cords here, right? Because those are typically only rated for 10A anyway. So that would usually be 3x0.75mm
2. And frankly, even if you could make the conductors thinner, there are diminishing returns. The insulation still needs to be mains-rated, so you can't really make that thinner (do NOT use microphone cable for mains voltage like someone suggested
). It might also be plugged and unplugged, bent, pulled, stepped on etc reasonably frequently so the jacket needs to be at least somewhat robust. Using something more flexible than standard PVC here would make a pretty big difference though. Maybe someone does "premium" IEC cords with rubber/silicone/textile jackets.
