Why? It's a flight characteristic. All planes with low slung engines will have more pitch up force on full throttle. The MAX just has a bit more. It's not like this is some sudden onset operating region where the dynamics change hugely. What happens is that you pull on back on the stick, and at full throttle, you'll notice stick pressure needed to maintain that AoA starts to lessen and invert. If you want to keep that AoA and full throttle, you need to push down, sometimes really hard. That's quite intuitive. The auto trim exists to help the aircraft maintain control input without physically exhausting the pilot. If you don't have trim, then you have to sit there and haul back super hard on the stick whenever you want to climb or descend. MCAS is just a special case of that for a specific situation.
Obi, you did not understand what I was talking about.
1. I am aware that the MAX induces more nose up under throttle. And they way I have read it is not "a bit more," it's actually "quite a bit" more. And yet, this is not what I'm referring to in my last couple of posts between us.
2. There is an additional aerodynamic problem that is caused by the larger engines. The plane was designed to be aerodynamically efficient and stable with the original engines. As AOA increases, the belly of the plane starts to increasingly get exposed to the oncoming air. And these larger engines, which are placed farther forward, are now getting hit at an angle. They are no longer just thrusting the plane. They cause lift and drag simply by their aerodynamic shape. But due to their farther forward position, the lift is not acting at the center of mass of the plane, anymore. It is closer to the nose and is creating a twisting force, causing the nose to pull up. Due to the higher engine placement, the drag is no longer acting below the wing as much, which should be counteracting this force, more, in the original placement.
3. In fact, the aerodynamic lift from the engines is acting on the plane through the wings. So this is increasing the torque on the wings (in addition to the normal loading and effect of engine thrust) and might induce a small fraction of an inch more than the normal twist to the wings, increasing the wings' AOA. This is certainly true (as an average, and to an engineer) on some level. Everything has flex. Whether it is significant or not, who knows.
4. Unlike the nose up effect that is caused by throttle, this nose up effect induced by the aerodynamics is not significant at lower AOA. But it increases ever more at higher AOA. This is what makes the high AOA reagion unstable on the MAX. The engine effect would be more static and controllable, as you say, by the pilot, simply by adding trim based on thrust. Unstable doesn't mean unflyable. If it is minor, it would just mean more manual labor/tweaking/monitoring to keep the plane in this region. Since it is probably relatively close to a stall, this might make it unsafe.
4b. Whenever you have some effect (aerodynamic lift of the engine) which causes something else (nose up of the plane) that increases its own effect (the aerodynamic lift of the engines is now greater), this is what might be called a positive feedback loop. Unchecked, it causes some degree of instability. You can't completely negate/counter this dynamic variable with a static change (like setting trim to X).
5. MCAS does not adjust the trim when you change throttle. It reacts only to AOA. It therefore is not strictly there to counterbalance the effect of the throttle.
6. I might be wrong, but because the pilot makes trim adjustments for other reasons and for intentions unknown to the MCAS system, it would be impossible for MCAS to be able to dynamically and actively negate the aerodynamic effect of the engines without making some degree of unpredictability in handling to the pilot. This is why I believe the MCAS is more like a "Saw Stop." I would guess it acts more like a last ditch anti-stall, despite how Boeing wants to classify it. Also, to actively/dynamically negate the aerodynamic effect of the engines, MCAS would have to be keeping track of the changes it makes; which this either isn't the case (since it is known to be able to repeatedly fire, indefinitely), or there was an actual bug (whether coding or design oversight) in the original implementation.
6b. For active electronic dynamic stability to work best, with the fewest compromises, IMO, requires fly-by-wire. Airbus. F16. W/e. The computer has to be able to take the user input and decide how to implement that in the moment (mixing this in with the juggling), so that the pilot gets a consistent response. There is a huge amount of work and risk and expense to get the response tuned/refined to be efficient to human pilots... because someone has to test it.
I state all these things like facts, but it is just what has been spread in the internet news. And I may be inferring some of it incorrectly. As for the physics/aerodynamics, full disclosure; I'm not an engineer in the state of Oregon, but I like to pretend I am, on the internet.
I'm sorry for the confusion you have had over this, thinking I'm talking about the engine thrust effect. And I thank you for adding your insights and for engaging my questions.
