https://leehamnews.com/2019/04/03/et302-used-the-cut-out-switches-to-stop-mcas/Pilots apparently had an air speed indicator disagree. There were following protocol for that issue when the MCAS fired.
Pilots applied runaway stab trim protocol, as proscribed by beoing, in order to disable MCAS. They cut out stab trim, according to black box analysis.
At higher speeds, an MCAS'd stabilizer can not be moved back up by hand. The pilot could not release the yoke to relieve pressure on the stabilizer in order to re-trim the plane, because this would have crashed the plane, faster. They were at only 1000 feet, shortly after takeoff.
Pilot actually broke procedure by flipping the stab trim back on, in an attempt to move the stabilizer back up with the motor into some position that would not crash the plane. But MCAS fired again. And they could not correct it in time.
The button on the yoke overrides the MCAS commands. The MCAS kicks in again (and again, that's the flaw) 5 seconds after the pilot releases the yoke's trim button, but that's plenty of time to flip the cutout switches.
These pilots turned the stab trim back on only to move the stabilizer up. They would have been pressing the up button. But MCAS fired again, and this did something.. I'm sure they didn't wait 10 seconds, watching MCAS do the opposite of what they were desperately trying to do without some combination of pressing or repressing the trim up button to try to get it to respond to their manual input while also pulling back on the yoke with all their weight to try to keep the plane from crashing.
Many (well, a few, or some) pilots in previous 737 MAX flights have saved the day by doing just that. Why? How did they know? Because after the lion air 610 crash Boeing put out a safety technical bulletin explaining just that. We're going in circles in this thread...
According to the airline, the Ethiopian Air crew received all updated training after the Lion Air crash. Per what has been discovered from the black box, it looks like the pilots followed the recommended protocol in the way they had been trained. They cut out stab trim. The erroneous AOA/MCAS might have put the plane in an unrecoverable situation, stuck between a relatively slower crash and a quicker one. Manual trim not an option. Losing altitude; can't get the nose back up.
I said it a couple days ago, that MCAS needs to be able to be deactivated without cutting out stab trim. I would also not be surprised to learn that MCAS will override the trim up button, if it fires while the button is being pressed. Whether by bug or by intention. It is, afterall, an automatic action that is supposed to prevent the pilot from doing something he is not even supposed to be aware of, that the MAX handles differently than the other 737's in a way that makes it more prone to nosing up and stalling when in high AOA. If you are supposed to be able to fly the plane the same, then a 737 pilot might be intentionally dialing in manual trim up when he accidentally stalls a MAX, in which case MCAS would be useless to prevent this scenario if it doesn't override the pilot's manual trim up button press.
If there was a way for the pilots to have saved the plane by "being smarter," then whatever it is they were supposed to have done should probably be in the emergency procedure as a memory item and practiced in this kind of scenario. And if it's not 100% reliable without a simple procedure... no complex algorithm of if/and/then branches or "waiting to see what happens after you do w/e".... then it is probably too complicated to deal with this kind of scenario. The scenario appears to be pilots being dumped into a situation where they had maybe 40 seconds to figure out a way to get the the nose up... while at least one of them is fully preoccupied with heaving up on the yoke.
