Blanco Lirio channel from Aug30
If you start the vid at 3:25, it seems this is circular logic to prevent calling a spade a spade. If you have time, just listen from 3:25 onward for about a minute or 3. It's quite impressive.
"MCAS is ONLY there to make the plane behave like previous models. The plane is stable, because it meets FAR 25. FAR 25 is important so that the plane will behave predictably. The MAX does not behave correctly in two spots which are pretty important; namely high speed stall and low speed stall. So basically anywhere that the feel of the controls is especially important. So MCAS is added to fix this. Only to make the MAX behave like other 737's, not because it doesn't meet stability requirements of FAR 25. Now are you 100% confident?"
It seems like regulatory body red tape and doublespeak is replacing engineering either for legal reasons or an attempt to avoid public scare from key buzz words. It would be more reassuring if the industry PR's kept to logic.
I've been mixed up a few times, before. But my current understanding, to date:
It sounds like Boeing added MCAS to make the control feedback feel right at normal cruising speed. Then they increased it 3-4 fold after finding out that at lower speed you need even more angle for the controls to feel right. Basically, that stunt that Airbus pulled with one of their planes, by doing the "low and slow" in front of a live press audience? If the plane were a 737 Max without MCAS, it wouldn't necessarily have crashed. But the pilot may have declined to perform it in the first place, not feeling it was safe to do on purpose. Esp so low, forcing him to distribute his attention across multiple variables while having less than ideal feedback on the control column.
I hope this is right. And no it doesn't sound terrible, as long as this part of the AOA envelope is fairly extreme and unlikely to ever be utilized in the course of duty, and even if, probably not intended to remain in this state for long.
