Author Topic: Lithium Ion Batt. Storage  (Read 1338 times)
Offline BILLPODTopic starter
« on: August 23, 2020, 06:24:48 pm »
Good Morning All,
     For several years I've been harvesting the 18650 Li-ion cells out of laptop batteries.  I've weeded out the bad ones and charged up the good ones.  I've accumulated around 20 and am arranging them in a cardboard box.  I know there must be a better way, so does anyone have a good system that works for them?
I've looked online and see some small plastic boxes for this use, but nothing that can hold upwards of 20. :-/O
Offline tooki
Re: Lithium Ion Batt. Storage
« Reply #1 on: August 23, 2020, 09:58:29 pm »
It’s not hard to find ones that hold 10 cells. They cost peanuts on Ali: https://www.aliexpress.com/item/4000943546576.html
Online ledtester
« Reply #2 on: August 23, 2020, 10:38:03 pm »
Last year I found some nice small clear storage containers at Walmart which holds about 28 cells in a stack of 5 layers. It might be the kind of product, though, that's only available for one season -- i.e. some sort of special buy. I would just check your local Walmart/Target/Staples to see what they got.
As the number of cells increases, what you use for storage will also change, e.g.:
https://youtu.be/7wqPOhqILrE?t=2m50s
https://youtu.be/akLOCPeKavc?t=45s
Offline Nusa
« Reply #3 on: August 23, 2020, 10:44:44 pm »
I'd just appropriate a food storage container from the kitchen/store. If you later get more than it'll hold, get another container the same size. They'll stack.
Offline shakalnokturn
« Reply #4 on: August 24, 2020, 12:39:20 am »
Same here I have about 1kWh worth of 18650's stored in various plastic boxes then maybe another 2kWh that need testing.
The next worry is the damage they could cause, I'm considering making a large sandbox to bury all the little plastic boxes in.
Offline station240
« Reply #5 on: August 24, 2020, 09:50:00 pm »
Another option get some of the standard cell holders like this 4x5 one.
https://www.aliexpress.com/item/4000126245501.html
Put one on the bottom, put all the cells in with the + at the top, then jam the second holder on the top.
Holds the whole thing secure, till you need the cells.
Offline duckduck
  • 20Hz < fun < 20kHz, and RF is Really Fun
« Reply #6 on: August 24, 2020, 10:03:52 pm »
Some hobbyists that own remote control vehicles use flame-resistant battery storage bags for storing their Lithium Polymer batteries. I keep mine in a terracotta pot in the garage. LiPo batteries are (in)famous for spewing flames when physically abused.
