Not the same thing, but I once saw someone use USB cables creatively. He needed to do four terminal resistive measurements from x number of sensors of some kind. USB fit the bill exactly. Two wires capable of a high current, two wires suitable as sense wires, in a shielded cable. And of course readily and cheaply available connectors and cables.
Speaking of USB killers, there are cables with type A connectors, the type you normally plug into the computer, on both ends. These are used for plugging into to some network gear for configuration, if I recall correctly. But they have the unfortunate side effect of often creating large stray currents if connected between two computers, because of the slight voltage difference between the +5V rails on the two computers "fighting" against each other.
