I know nothing about biology. My degree is in physics so I don't know anything about effects of RF on health. If I worried I probably had a stash of equipment to measure it, fact that I don't have good measurement equipment speaks for itself
Still I am very curious to calculate how much exactly of RF power from that specific tower reaches my apartment for example. In nW/cm2?
In my case distance from tower to the antenna that I used in this test is 119 meters. No direct path unfortunately. Azimuth shown on Google Earth matches the azimuth of last 2600 MHz segment from that tower as shown on cell tower map. I think this is the one because frequency and bandwidth (20 mb) match.
If I calculate the ideal free space loss of power for 119 m and 2600 MHz:
FreeSpaceLoss = 36.56 + 20 log10(f) + 20 log10(d) = -82.23 dB.
This Vivaldi antenna has gain of about 6 dBi at 2.6 GHz (9 dBi at 3.5up).
So how do I accurately estimate the power of that transmitting antenna? I assume that it is 60 or 120 deg segment, most likely 60.
Now in terms of power density if it was really 1 kW out
Pd = (Pt * Gt) / (4 * Pi * R^2) or in meters
Pd = (1000 * 10) / (4 * Pi * 119^2) = 0.056W/m2 or 0.0056 mW /cm2 or 5uW/cm2.
European Parliament recommendation is 10 nW/cm2 so if it was true 1kW it would be waaaaay out of norm according to EU but in US 579,000 nW/cm2 is a norm.
Also I have to say that two things that someone mentioned here - base station only transmits periodically. True, but only for channels that used to voice. This 20Mb channel - is continuous, always on data stream. All GSM stations have broadcast channel (strongest) and control channel(s) and these are always on.
Not all buildings allow base stations so cell companies ended up installing base stations on lower building - see elevation of that base station is 14 meters. My apartment is 68 meters above ground level. It means that apartments on floors 5-7 exposed directly to the signal if transmitting antenna is pointed horizontally.
