Author Topic: LMI 6431AC help required  (Read 670 times)
Offline Sighound36Topic starter
« on: April 24, 2022, 06:51:53 pm »
Hello Chaps
I would appreciate a little assistance indentifying a part Its stumping myself so any suggestion on what this is and where I could source some would be great. I am just being dumb possibly  :-DD However on the off chance I am not.
The offending article is TO-92 package LMI 6431 AC if these are not availble a suitable replacement that could be recommended would be great as well.
If this is in the wrong section then apologies to the mods
Many thanks
Sighound
Offline Gyro
Re: LMI 6431AC help required
« Reply #1 on: April 24, 2022, 08:33:51 pm »
At a guess, it's a TL431. Maybe vanilla, maybe a variant. AC suffix are normally 1% tolerance 0-70'C.
EDIT: https://www.alldatasheet.com/view.jsp?Searchword=6431AC&sField=1
« Last Edit: April 24, 2022, 08:37:52 pm by Gyro »
Best Regards, Chris
The following users thanked this post: Sighound36
« Reply #2 on: April 27, 2022, 09:52:43 am »
Hello Gyro
Thank you for your suggestion it is appreciated.
Will look into this later.
Sighound
« Reply #3 on: April 28, 2022, 02:51:31 pm »
After managing some more time on this subject now:-
Possible candidates so far:-
https://www.ti.com/lit/ds/symlink/tl1431.pdf?HQS=dis-mous-null-mousermode-dsf-pf-null-wwe&ts=1651151931504&ref_url=https%253A%252F%252Fwww.mouser.com%252F
Or the slighly more updated version I am suspecting either will be fine assumiming these are a match for the original part.
https://www.ti.com/lit/ds/symlink/tl431.pdf?ts=1651120920131&ref_url=https%253A%252F%252Fwww.google.com%252F
Many thanks
Sighound
Online Zero999
  • 0999
« Reply #4 on: April 29, 2022, 11:52:14 am »
Did the part work before the legs came off? If so, it's possible to file down the package, solder some new leads and cover it with epoxy. You'll need to be extremely careful, when re-soldering it to the board. Wrap a damp piece of paper towel round the new leads can protect them from getting too hot for the epoxy and solder it as quickly as possible.
