That part doesn't detect zero crossings at all. You are thinking that it is more than it is, but it's still just a TRIAC, and behaves like a TRIAC, it's nothing special.
The gate happens to be enhanced to give extra sensitivity, thus it can be triggered with a very low voltage and current. That's what they call "logic level". ugh.
I think it's a little reckless for the datasheet to say that it's intended to be directly triggered from a micro-controller without giving an example circuit.
Sure it can be directly triggered from a microcontroller, but that microcontroller will need to be on the same AC side that you are switching,
because the TRIAC must get it's gate current from the MT2 side of the device.
If you are using it to switch AC loads, then you should still isolate it from your micro. I suppose , in some embedded applications, beyond human contact,
where the micro is directly on the AC mains side, non-isolated, you can directly trigger off a micro I/O pin.
Other than that, you will still need an opto-isolator, diac, and optional zero-crossing detector to trigger it.
