Author Topic: Looking for cheaper blue tooth module  (Read 2513 times)
Offline timbobTopic starter
« on: February 23, 2013, 03:33:55 am »
Hi, I am working on a project for school that uses blue tooth to send data from one microcontroller to another microcontroller. the cheapest blue tooth module i have found were these http://www.parallax.com/StoreSearchResults/tabid/768/List/0/SortField/4/ProductID/890/Default.aspx?txtSearch=blue+tooth. i was wondering if any one knew of a cheaper blue tooth module.
Offline Smokey
  • Not An Expert
Re: Looking for cheaper blue tooth module
« Reply #2 on: February 23, 2013, 08:35:20 am »
Nice.  Link Bookmarked.
Under 8USD shipped.  Seriously.  I love China sometimes.
« Reply #3 on: February 23, 2013, 08:40:11 am »
I'm looking for one that if I sell my Project, I can keep go back to and order more. but for test it will do. thankyou
« Last Edit: February 23, 2013, 08:41:57 am by timbob »
Offline kripton2035
« Reply #4 on: February 23, 2013, 09:26:44 am »
when you buy in china, the deal is that you buy 20% more to repair if it fails ...
if it fails too much you loose, if it does not fail you win !
the modules from parallax or others come from china too but they do the repair so that explains the high price
also the characteristics of the module is not mandatory the same you must have some tries.
Offline daveshah
  • Country: at
    • Projects
« Reply #5 on: February 23, 2013, 10:59:17 am »
I have used a module like that, and MCU-PC communication worked very well; however, MCU-MCU communication may not be possible and requires some hacking.
A better way might be with these two modules:
Master: http://www.ebay.com/itm/New-MIni-3-3V-wireless-Bluetooth-Transceiver-Master-Module-Serial-Port-30ft-TTL-/261053250441?pt=LH_DefaultDomain_0&hash=item3cc7fc7b89
Slave: http://www.ebay.com/itm/New-Mini-3-3V-wireless-Bluetooth-Transceiver-Slave-Module-Serial-Port-30ft-TTL-/261053259306?pt=LH_DefaultDomain_0&hash=item3cc7fc9e2a
Offline mswhin63
« Reply #6 on: February 23, 2013, 11:44:04 am »
I am currently using these modules for my Astro-photography right this moment. They work a treat. I have been using these for about 2 years without skipping a beat.
