Author Topic: Wireless link for USB cable ?  (Read 3988 times)
Offline Kiriakos-GRTopic starter
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« on: November 29, 2011, 07:08:08 am »
Does any one know if there is out there any solution's of wireless link for a USB cable ?
Lets suppose that we need a wireless link that it would replace 8 meters of cable.
Online Simon
  • Global Moderator
    • Simon's Electronics
Re: Wireless link for USB cable ?
« Reply #1 on: November 29, 2011, 07:15:59 am »
I think you can get usb cables with repeaters in them to extend the range. Otherwise your looking at bluetooth or wifi
Offline Psi
« Reply #2 on: November 29, 2011, 07:46:47 am »
There is a good range of solutions for usb over ethernet.
So you could wifi one of them
Offline Jimmy
« Reply #3 on: November 29, 2011, 11:04:28 am »
Kiriakos-GR
Some of the usb over ethernet don't work with the plc's I use so it depends on what you are trying to run I guess
Offline NiHaoMike
    • Facebook Page
« Reply #4 on: November 29, 2011, 02:57:52 pm »
They make wireless USB adapters, but you'll need better antennas to get the range you need.
Offline metalphreak
  • http://d.av.id.au
    • D.av.id.AU
« Reply #5 on: November 29, 2011, 04:35:10 pm »
http://www.jaycar.com.au/productView.asp?ID=YN8406
That plus a wireless point to point link could work. It however demands a PC running their special software, so you couldn't arbitrarily link one usb device to the physical usb port of the host.
Offline slateraptor
« Reply #6 on: November 30, 2011, 01:25:15 pm »
As a possible sol'n:
http://www.rovingnetworks.com/products/Bluetooth_Adapters
Look under USB dongles.
Offline SgtRock
« Reply #7 on: November 30, 2011, 03:38:53 pm »
Dear Kiriakos:
--Is this (see below link) the kind of thing you are looking for? I just ordered one of these with my new computer kit.
http://www.geeks.com/details.asp?InvtId=AM10
"You should never bet against anything in science at odds of more than about 1012 to 1."
Ernest Rutherford 1871 1937
Best Regards
Clear Ether
Offline kaz911
« Reply #8 on: November 30, 2011, 07:35:14 pm »
http://www.kvms.com/Section/Wireless-USB-Extender.aspx
something like that?
  • Country: gr
  • User is banned.
« Reply #9 on: December 03, 2011, 04:58:15 pm »
Yes something like that.  :)
