Author Topic: Looking for documentation for a TEAC MT-2 Cassette Drive  (Read 4057 times)
Offline johnhTopic starter
« on: November 21, 2019, 03:50:02 am »
Looking for connection details and documentation on the TEAC MT-2 Cassette Drive
Note: this is not the streaming drive.  TEAC MT-2ST
Found some documentation that might be relevant http://www.mrt.tas.gov.au/mrtdoc/dominfo/download/UR1989_20/UR1989_20.pdf
But, it doesn't have any connection details
Thanks in advance
Re: Looking for documentation for a TEAC MT-2 Cassette Drive
« Reply #1 on: November 22, 2019, 08:06:48 am »
So nobody here can help.   :(
Can someone suggest another forum I could try.
Offline tooki
« Reply #2 on: November 22, 2019, 04:27:49 pm »
Page 30 of this PDF has a very basic schematic, and pp 2-3 describe things: http://www.bitsavers.org/pdf/teac/MT-2ST/MT2ST_UR1991_11.pdf
Don’t be put off by the URL, the document itself says it’s for the MT-2.
Offline icraftcrafts
« Reply #6 on: June 12, 2021, 07:07:15 pm »
Sorry to resurrect an old post. I have a Cristie CS6 unit that uses the mechanism that the OP posted about. The company has a CS5 unit on their website history page and it was made in about 1981. I might dig further too, so thanks for the links, everyone.
Offline jdreesen
« Reply #7 on: July 08, 2021, 11:37:23 am »
Be my guest :
 ftp://ftp.dreesen.ch/teac/Teac_MT2_user_manual.pdf
...and do not forget to change the capstan roller......
« Last Edit: July 08, 2021, 11:43:15 am by jdreesen »
The following users thanked this post: icraftcrafts
« Reply #8 on: July 09, 2021, 08:26:52 am »
    :)   nearly fell off the chair when I saw this.
But when I tried to download it  :(
curl ftp://ftp.dreesen.ch/teac/Teac_MT2_user_manual.pdf
curl: (9) Server denied you to change to the given directory
Offline Kaluluka
« Reply #9 on: July 09, 2021, 08:34:28 am »
Try:
Offline jdreesen
« Reply #10 on: July 10, 2021, 08:50:05 am »
oops, correct URL was   ftp://ftp.dreesen.ch/Teac/Teac_MT2_user_manual.pdf  ( upper case T...)
I have 2 MT2 units, one has a totally hardened capstan roller, the other capstan roller was totally mushy. I replaced both with 3D printed rollers, using innoflex as filament. Yet to try out as I did not yet finish my program to control the MT2.
Similar printed capstan rollers for QIC drives worked out OK.
Jos
The following users thanked this post: johnh, icraftcrafts
Offline megatimbo57
« Reply #11 on: March 04, 2024, 11:00:20 am »
Hello all  , i have a Roland MTR 100 Dat cassette Drive there is a rubber roller that has degraded,do you know the size and dimensions for a replacement ?and how this can be done ,tear down, it seems to be fairly easy to get at.
Thanks Tim
