Author Topic: Looking for RGB or RGBW values of a sunrise  (Read 6015 times)
Offline BrianHG
Re: Looking for RGB or RGBW values of a sunrise
« Reply #25 on: September 21, 2017, 04:30:33 am »
Use 2 RGB sensors.  1 for the sky and the other for you LED strip.  Match the color characteristics.  The RGB sensor has the built in analog with temperature correction to guarantee a fixed reference reading from device to device.  Also, a cheap pinhole lens may be used to capture the sky with a narrower field of view.
__________
BrianHG.
Offline cdev
« Reply #26 on: September 21, 2017, 04:52:12 am »
Please let us know if you capture the legendary green flash. (a brief moment of green light that occurs at a specific moment during the sunrise and sunset as the light from the sun is emerging or vanishing.)
Offline BrianHG
« Reply #27 on: September 21, 2017, 09:29:20 am »
Wicked.... I've never seen that before....
__________
BrianHG.
Offline cdev
« Reply #28 on: September 21, 2017, 03:48:15 pm »
Indeed,
Okay, now you need to see it.. how?
 you need to have a clear view towards the west or east. Very flat places are the best- or in an airplane. I think the reflection off the water magnifies it so you're most likely to see it at a beach alongside a large body of water.
Ridgetop hiking, at sunset, I think you may have a better chance although it seems to me the inversion/blob kind of green happens less from high up.
(to be honest with you I don't know the science, just trying to go from memory, sunsets from ridges while hiking=spectacular/colorful..)
If you don't live anywhere near a beach, but fly from time to time, perhaps your best chance of seeing one soon is from the air?
Quote from: BrianHG on Today at 03:29:20>Quote from: cdev on Yesterday at 22:52:12
Online Twoflower
« Reply #29 on: September 21, 2017, 05:51:23 pm »
Sorry if my simple description from the first post was misleading. A as good as I can manage with the RGBW sources is good enough for me.
@cdev: No worries about looking direct into the LEDs. It's behind my bed and cowered with a opaque diffusor.
Wrt different sunrises at different locations. That's actually one additional plus for the sensor: It's easy movable and I can ask someone who travels at a nice place to do the recording.
Yes I could use my camera in HDR or do some additional calculation to compensate changes of the exposure time (I would keep the diaphragm fixed). But I feel that this is rather cumbersome setup; especially as my tripod is a heavy load (Manfrotto) and I don't own a car.
@rs20: About the usage of the white channel: Thanks for the heads up. It would be very obvious to get completely overblown rendering of the record. That needs to be taken care of. I noticed that extreme wide range of the W channel too. I think ill still record it and keep the data but not use it.
I think a mismatch of the Filters and the LED colour might be bad. Just imagine the red LED is shifted compared to the sensor that only 20% passes the filter the RGBW sensor: The reading will be much to low and you would think you need to beef up the R channel more than necessary.
I see the sensor like a small project. For both the Cam and the Sensor I need the hardware setup (opaque dome or reflector, ...) the calculation from the sensor/cam needs to be done. Here the sensor gains a bit as I have already the RAW data in a nice format. And I have several controllers flying around which are currently waiting to be used.
@BrianHG: Probably I'l use one sensor which is used for both usage models. As I don't plan to compensate changes on the room I do a single calibration run to identify correction curves that are applied to the RAW sensor data on a PC. the processor might have enough CPU power to do this online. But imagine something red falls on the sensor and you will wake up under a green-blue sky :-DD
The pinhole lens sound like a good idea! Worth a try.
@reen flash: (OK, that's not a user rather a topic) I've watched so many sunsets over the sea and never was lucky to see one. I was aware of this effect and hoped so many times.
To my understanding a place with a view over the sea will do. And the weather conditions must be perfect: The sky must be clear and the right temperature conditions over several air layers must help to bend the light a bit around the earth surface.
I'm not sure if a plane is helpful. So far I only saw pictures from it on sea level.
Just for your entertainment I've added two pictures of the driver (6+1 12bit PWM channel, the MOSFETs are bottom side mounted, controller not mounted) and the LED stripes loosely placed in the profile with the opaque cover.
Edit: Added Pictures
« Last Edit: September 21, 2017, 06:30:58 pm by Twoflower »
Offline BrianHG
« Reply #30 on: September 22, 2017, 12:30:54 am »
As for the pinhole lens, you can safely point this instrument directly at the sun and it wont fry the sensor + the distance between the pinhole and the RGBW sensor controls the field of view the sensor sees of the sky.  Like a zoom control, but, no focusing needed.  IE, the further away from the RGBW sensor, the more narrow section of the sky falls on the sensor.  The closer to the sensor, more of the sky's view-able area will be centered on the sensor.
__________
BrianHG.
Online rs20
« Reply #31 on: September 22, 2017, 12:48:16 am »
The already-stated assumption is that the Red filter in the RGB sensor has the same response as the corresponding cones in the eyes. So, if the red LED is "shifted" such that only 20% passes the red filter, then that red LED only produces a 20% (proportionally speaking) response in the red cone, and it's exactly the right thing to do to beef up the R channel accordingly.
Meanwhile, matching the filter to the emission spectrum of the LED leaves your overall system completely blind to the fact that this LED only weakly stimulates your eye's red cones, producing far too little red light accordingly. Matching the filter to the LED instead of matching the filter to the eye is exactly the wrong thing to do.
The only issue that can be caused by a poor choice of LEDs is if the combination doesn't have a wide enough gamut. But since sunrises are not particularly saturated in colour (all the wavelengths are there in some quantity), I seriously doubt you'll run into gamut issues. (You'll know you've run into a gamut issue if your interpolation software turns into extrapolation software and requests a negative drive for one of your LEDs.)
« Last Edit: September 22, 2017, 12:56:42 am by rs20 »
Online Twoflower
« Reply #32 on: September 22, 2017, 06:57:51 pm »
@BrianHG: Right that distance might work as zoom. But I think as the sensor is very small this will end up in a huge 'crop factor'. Probably useful distances are in the mm range. But worth a try.
@rs20: Yes you're probably right as the sensor is designed to match the human eye. I missed that fact and just thought the total luminosity. So if the the LED has a strange centre wavelength the eye will be affected similar to the sensor. This should cancel it out. I checked the LED vs. Sensor wavelength. They're not that far away that this actually matter for my needs (620 vs 650nm, 520 vs 550nm and 465 vs 450nm).
