Author Topic: Super-Freq: Oscillators  (Read 6845 times)
TrentO
  • Guest
« on: October 31, 2009, 07:50:05 am »
I seek opinions on using standard through-hole clock oscillators to generate 'test-patterns,' if you will, that I can pump through my oscilloscopes, and my eventual o-scope project...
COTS frequency generators appear to be freeking expensive for anything above 5Mhz or so. I do have my eye on the Rigol DS1022 20Mhz for approximately $700US, but I have a feeling I'm going to outgrow that limit fairly quickly. The 120Mhz unit is about $4000US-- I don't think I would use it enough to justify that kind of purchase. However, paging through my favorite Digi-Key catalog, I see that there are myriad crystal and/or oscillator offerings-- could I simply provide the requisite +5v / +3.3v to the OSC can and use the output for testing? I could simply buy 10-20 OSC's in xMhz steps to get to my 120Mhz requirement! Are there limitations in doing so? What kind of circuit (apart from power) would I have to build in order to support this?
And finally, if I wanted to amplify these signals (and change the amplitude displayed on my o-scopes,) could someone recommend a circuit that I could build to do so? I would assume that an op-amp or two would be sufficient....
As for my O-scope project, I'm looking to build a three-chip DSO out of a PIC32, AD9283 ADC, and FIFO-- for no other reason than to learn about microcontroller development, ADC's and FIFO's.! But step one, in my opinion, would be to have the capability to produce a signal of known quantities/qualities.
Any and all assistance, comments and opinions are sincerely appreciated!
-Trent
GeekGirl
  • Guest
Re: Super-Freq: Oscillators
« Reply #1 on: October 31, 2009, 10:08:35 am »
Well, lets treat this as a learning exercise, first step is to get the datasheet, there will be a link on the page :), read it well, it will have some "typical" circuits :) this will do EXACTLY what you want, only thing is it will be a square wave only from the can. A simple external circuit will allow you to turn it into a sine or triangle wave :)
You would need to find an opamp that will give the required output voltage, and have a reasonable bandwidth.
Excellent idea :), cheap graphic LCD (or use a computer for waveform display), a decent ADC with a PRECISION REFERENCE supply, do not make the mistake of thinking that the +5v out from the linear reg is good enough for the vref of an ADC.  Something like an LM4040 is a good choice.
If you brainstorm, draw up a schematic (if you post it here, please make it an image from screen cap or PDF, so everyone can view it ;) we can give you pointers :)
Offline Mastro Gippo
« Reply #2 on: November 02, 2009, 09:41:54 am »
TrentO
  • Guest
« Reply #3 on: November 02, 2009, 11:24:20 pm »
Mastro Gippo--
I have seen this before, and I would have tried it, had it been based on the PIC architecture... I decided about two months ago to take the PIC route and not the Atmel route, in (re-) learning microcontrollers. I'm not looking to build an Oscilloscope for anything practical-- just to learn more about the practice of A to D conversion and perhaps driving a graphical LCD display.
-Trent
TrentO
  • Guest
« Reply #4 on: November 02, 2009, 11:34:17 pm »
Andrew,
Awesome response. I think I'll take your suggestions on as a project by itself. Are there any books on HF circuit design that you would recommend? (NOT that I want to build a frequency generator from scratch!)
Thank you very much for your opinions on the DG-1022-- I never really considered the PC-driven aspect of such a device-- I didn't think I needed the arbitrary-waveform aspect... but now that you bring it up, its probably worth considering-- I might have a need for it down-the-road.
-Trent
« Reply #5 on: November 05, 2009, 05:01:47 pm »
Mastro Gippo--
-Trent
I'm a pic guy too, but that thing is a nice way to learn something new! Also, it's a basic oscope for very little money! I think I'm going to get it just for the cool factor, I don't think I'll ever use it :)
