Good question, difficult to say, the meter is at/near/over it spec sheet limits, and the voltage source, MV106, is over its spec sheet; however the MV106 has a claimed resolution of 10nV which I've yet to see given the limits of my equipment. However, good designers should report a conservative value in spec sheets for gear. Would be interested in your report. I've also tried different PLC settings on the 3456a, and it does improve on SD values a little bit, suggesting some variation is still from the 3456a.
Nevertheless, the video hopefully shows a 3456a still provides excellent capability as a DC DVM despite its being 30+ years old and that acceptable DIY calibration can be done with some perseverance. Depending on what is costs in your country, 3456a is often a low cost DVM that provides stable 1uV resolution easily and can be accurately calibrated by owners, also for low cost. Not to mention general ease of repair, should it happen, making the TCO, fairly affordable at least to USA owners [ because I'm most familiarly with the going prices].
What portion of that SD is the voltage source and what portion is the 3456?
Just for fun I fired up the 8846A and a PD2010 to see what it looks like after 11400 samples. (in the dark of course
We will have to wait about 5 hours for the picture at 100NPLC
