A few weeks ago LTSpice started acting weird, simulations would run, give sensible results and then on a second 'probing', the results would be 'weird', a part of my circuit is a resistor divider fed with a DC voltage that should have yielded 1.25V but the probe result would drop to 0.89999323232v or something similar.
I gave up because I had the data I needed.
Tonight, I find i've some free time so I tried to start LTSpice and it doesn't run.
No errors, nothing in the system logs, no frozen process, nothing.
I've tried running as admin, uninstalled, cleaned out the relevant bits of the registry, deleted folders, downloaded and reinstalled, registered DLLs, all sorts and it just doesn't work, same again, no errors, no messages, no system events.
I'm not really willing to rebuld my system for hwat should be a simple fix but I'm damned if I can work it out.
Any ideas?
Windows 7, up to date with patches and service packs, Lenovo Thinkpad i5 8GB hybrid hard drive.
