The 0722 is actually one of the ones I have, IIRC, but haven’t tested because I still haven’t bought an indent crimper.
OH! The other thing to try: D-Sub HD female terminals (size 22). Specifically, the kind that are basically a split tube. These come in various crimp styles (indent, F-crimp (the regular m-shaped crimp)), solder cup, etc. I’ve been using these for a while and they’re surprisingly good on square header pins.
For example, for indent crimp, look at Molex 1731120226.
I’ve been using ones similar to TE/ AMP 1658686, crimped on and then insulated in heat shrink, which not only insulates it electrically, but also gives it more tension on the pin.
